Wall mount / bracket question
Timberarrows
Whoever wanna buy wall mounts, can pm me ah.. I got lobang for cheap and good wall mounts! :) All kinds, swivels and just normal!
AltecZalea
wall mounting
anyone got recommendations for wall mounting service?
i wanna get my flat screen wall mounted but i don't know how.
any good online Samaritans kind enough to recommend service providers for wall mounting, feel free to pm me.
thanks
yaozhi
LCD MONITOR WALL MOUNT
Hey guys,
Anyway idea where i can get wall mount for computer monitor at acceptable price?
A rough guide on how much will it cost and any things i should take note?
Thanks.
alanchia67
If monitor is VESA mount compatible, you can go check the mounts in many stores and even DIY shops.
JuveZzZ
Any shops recommended shops in SLS that sells wall mounting bracket?
Looking for a wall mounting bracket
Prefer to be in SLS, etc
Looking for Sanus brand or Samsung ones for a 40" LED TV, think need the slim type....
Any shops to recommend that is cheap and good service?
rza29
i saw sim lim tower 3rd level got 1 shop selling wall mount kits. u can go there take a look. i dont have shop name..just walk around can find as quite small
Carova.
hi, any contractor to recommend? For wall mounting service..
reddae
How much does it cost to wall mount?
My tv (with the brackets) is going to be delivered soon. I intend to wall mount it after some renovation.
Any ideas how much it is going to cost? Any recommendations on who to engage. Thanks!
Pokémon
How soon will the renovation complete? Were you given the free wall mount during purchase? If yes, some allows you to exercise this option within 3 or 4 months, depending on the brand.
reddae
My Reno should complete in 2 months time. Bought the LG lw5700. Yes, given free wall mount but the guy who called to arrange the delivery says the tv mount is on the same date as delivery. Is this true?
mikeeeey
hijack on this thread. sorry.
if i had lost the bracket given previously, now i shifting to new place. how much does it cost to mount it without the given bracket? (buy new bracket + mounting)
Pokémon
You might want to check with LG. When I bought mine, the salesperson said I can still request for the wallmounting to be done within 3 months after purchase, though the wallmount will be delivered together with the TV.
reddae
Ah.. thanks. I will call them tomorrow.
F3Rm1nat0r, thanks!
bleonz
Yes...for LG, usually wall mount/bracket will be delivered together with TV. The contractor cum delivery man will help u mount on the spot.
reddae
Thanks for the reply. That's my impression too. Sigh. At least, got the brackets. If anyone knows the installation cost, please post, thanks
