touchme
- Mar 29, 2009
yup, thk god, my ports are all facing downwards & sidwards, so no issue..Was planning to visit my metalworkman to fab the above bar, until i check out my home hw shop, hoping for an hevy duty eye- hook bracket. Boy, was I lucky..this is what I found..
Bought a pair, a pair of splitter bolts. Spend today drilling 2 holes on wall, fastening the brackets.
ignore the other 2 holes above, mistakeably too big.
Shocker: My drill went through next door neighbour's room, wtf, the separating wall only 2 inches wide, hollow block somemore...that's another issue)
Sawned off the protruding bolt thread, hang TV on the 2 eye hooks, with 2 x M6 bolts on back of TV...Yes, only 2, and Tada..!!
Closer Look (top down overall, side-bottom-up, top down-single):-
Unfortunately the bracket's profile is a little weird, with a little notch, otherwise would hv been closer. However the lower back half of TV is fatter by 12mm than the top-half, so it is quite ok. The lower half is pressing against wall. (speakers side, woofer back against wall , not bothered)
Now it's back to sorting cables..
Achievement: 12mm spacing, $5 TV-mounting, and 2 extra holes to putty off + 1 neighbour's hole. Darn happy!
but i still got the invoice with me
