Wall mount / bracket question
wacko
Thanks wacko for your prompt response! Am i right to understand then the hole saw is the industry standard size? If yes, i will not get my designer contractor to drill the hole if it is bigger than the hole saw size.
Good idea on the circular table grommet. I fail to think of that. :s12:
no standard size for hole saws, but your contractor should have a hole saw that is of the same size as round desk grommets that he should also carry.
Mr_Farmer
may i know how thick must the wall be? i'm asking because i made a rotating panel on top my cabinet to mount the tv and i scared the bolts will come out the other way!
mrsun18
I suppose you are asking for the thickness of wall to use rawl bolt?
Rawl bolt is only suitable for concrete, brick, or similarly type of walls. If your panel is made of wood, you can't use it.
You need bolts and nuts like this (there may be other possible solutions):
The wooden panel must be strong enough to hold the weight of the tv set.
saintgtril
This is what he did yesterday. A hole saw was drilled on my feature wall and the round desk grommets is used to cover the hole. To share with everyone here:
do find out the dimension of your TV set. Apparently, the exact location of the hole is determined by the size/dimension of your TV.
Because my ID only drill a hole on the feature wall. The delivery man will mount the TV on my feature wall. So what my ID recommend is to tell the TV installer to mount the TV height to be around 700 to 800 from the floor. He said this is a comfortable level for my viewing. Any comments?
I am getting LG 55UF860T TV - its dimension is 123 (length) * 73 (height). :s22:
for-kel
wall mount/bracket
How to know which wall mount/bracket is suitable for the tv i going to buy?
Going to buy online a lg 43" tv bt they like no free bracket so need to buy myself.
Anyone can recommend a cheap(and good) bracket
Any different type needed if using feature wall?
Thanks
petetherock
Moderator
Moderator
There are many on the market.
I suggest you get one suitable for 50" or even 60" if you intend to upgrade in future.
The shop that sold you the TV probably has some, or try the marketplace / ebay. Many units are often put on sale by people who don't need theirs.
Eg, I got a Sanus that can take up to 70" for $80 off the marketplace forum.
petetherock
Moderator
Moderator
Useful:
http://www.soundandvision.com/content/4-things-keep-mind-when-wall-mounting-tv#JPux2kxcSO1OY3IR.97
4 Things to Keep in Mind When Wall Mounting a TV
As a custom installer, meeting with clients building new homes, remodeling, or just looking to upgrade their entertainment systems is a big part of my job. And after 17 years of walking through job sites and looking at blueprints, I pretty quickly hone in on the few key areas that determine the project’s difficulty and cost. While decisions like speakers, electronics, and TVs are important, it’s the “big picture” infrastructure items that need to be focused on early. Ultimately, with the correct infrastructure in place, virtually any gear can be installed and—hopefully—leave the project prepared for upgrades and technology changes down the road.
When it comes to installing a new TV, there are four big-picture items beyond just making sure the mount is securely affixed to the studs. These are power, sources, audio, and control. Let’s look at each.
1. Power
Obviously, the TV won’t work without power, and if you can’t just point to the wall and say, “Have the electrician put an outlet right here,” it needs to be addressed. By the National Electrical Code (NEC), you can’t just run an electrical or extension cord through the wall, but there are several solutions like Power-Bridge that allow easy—and safe—power connections without bringing in an electrician. Of course, if no outlet is nearby or you are working with something solid like a brick fireplace, concealing the wire for a finished look will be trickier.
2. Sources
Knowing what sources will connect to the TV determines the type and number of cables that need to be run. Even with just basic cable TV, is there a jack already there? Or can one be intercepted in an attic, crawlspace, or other room? While some source components like Apple TV, DISH Joey, and DirecTV Genie Mini are slim enough to install on the wall behind a flat-panel TV—greatly simplifying Installation—most components require some kind of cabinetry or shelf. The location of the sources determines the cabling length and the installation’s difficulty. We recommend pulling a bundle of HDMI, CAT-rated data and RG6 coax cabling for flexibility, especially if you won’t be using an AV receiver as a source switcher. We have started pulling multiple extra CAT cables to displays, as the wire is cheap and offers so many great uses, from Ethernet, to IR, to HDMI distribution via HDBaseT. Of course, installing some conduit or a pull-line can ease adding more wiring down the road.
3. Audio
With very few exceptions, modern TVs deliver abysmal audio quality; fortunately, there are many ways to improve it. From an installation standpoint, adding a soundbar is often just a single digital audio cable from TV to bar. However, depending where the bar is mounted, this might mean concealing another cable—and power—inside the wall. With a traditional surround system, enjoying improved sound from any streamed programming like Netflix or Amazon Prime requires sending the TV’s audio to the AVR. Again, this can be accomplished via a digital audio cable. However, TVs and receivers have been supporting an HDMI function called ARC—Audio Return Channel—for several years, enabling the TV to send audio back to the receiver down the same HDMI cable it uses to receive video.
4. Control
As the install grows from TV only, to TV with a set-top box, to multiple sources, to adding an audio system, the remote pile grows quickly. Beyond just the convenience of a universal controller (probably the best investment you’ll make in your system), sources located out of sight will require a control solution that can work through cabinet doors or even walls. While infrared (IR) repeating systems are less expensive and can do the job, they are more prone to interference and aren’t as reliable as radio frequency (RF) solutions that don’t require pointing the remote at a target.
Read more at http://www.soundandvision.com/content/4-things-keep-mind-when-wall-mounting-tv#m9q5hAQHvbR2bJGu.99
for-kel
Thanks for the advice, the tv i got did come with the bracket, (call again to confirm) thanks
Thanks.
jace88
This is what I have done after removing the wall mount. Use a hammer to knock the exposed end of the rawl bolt into the wall, this is to loosen it's grip on the wall. Then knock the exposed end from side to side (that means perpendicular to the wall), again to loosen the grip further. After it is sufficiently loose, pull it out. The hole can be patched up with premix putty easily. This only cost $2 - $3 from Homefix.
As for painting, owners usually will paint up the house again in any case to attract new tenants. You can confirm with your landlord.
I'm not worried about patching it up with the putty but more worried about the painting. I doubt the LL will repaint given it's a brand new place (I'm first tenant) and he said he's fine for me to do it as long as I restore it exactly as is. Any ideas how much painting would cost for that tiny bit to make it look like the rest of the wall?
mrsun18
I can see that you are a responsible tenant.
I suggest you go to a nearby paint shop (those that sell paints), during their off-peak, ie after about 10.30am to find out. They are mostly friendly and approachable. They will advise you what to do.
kun1he2
These are US type face plates.
You can try SLS, but it will be easier to import off Amazon.com
Thanks, noticed from amazon reviews that these faceplates aren't flushed flat behind, thus not suitable.
Decided to just leave the small hole in the wall as it is - especially since it is obscured by a cabinet.
Meanwhile, new TV just got mounted up with a bundled mounting kit.
Anyone need an old mounting kit that was for my old 55" LG? If yes, please pm me.
watchy
Wall Mounting TV Qns
Hi all,
Getting my first home and got a question regarding wall mount TV and appreciate if anyone can help me.
1. I watched multiple videos on mounting TV tutorial on youtube and the first step is always to find a stud to drill the hole. Is that applicable to HDB flat?
2. if i choose to use a fixed wall bracket from the agent, once the bracket is installed, will all the ports be inaccessible due to tight space between the wall and the TV?
Thanks!
the_gryffindor
Is there a vendor that sells the full range of Sanus racks? I want to get the full motion+ racks but couldn't find it in Singapore.
Henry Ng
Hi all,
Thanks!
1. The fixing is done by the Agent so user do not need to know. LG did it for me.
2. Most of the ports are accessible for LG. You just need to know how to do it. The tv just hang on the bracket and can be remove to plug in and hang back if you do not know how to access the ports.
Henry Ng
Thanks
That's strange.
If buy from store in sg, for > 40" LG do have free bracket and installation. They are professional installer.
icekachang72
Hi all,
I'm planning to mount my 42" LG TV when I renovate my new house. When I bought this TV 5 years ago, I didn't bought the mounting bracket.
Instead of going back to LG, where can I buy such brackets? Price?
Tq.
Henry Ng
Hi all,
Tq.
You can get the bracket but it is almost impossible for a lay man to install it nicely like a professional. Old model bracket may not be suitable for new model Tv use in future. To enjoy more, suggest at least a 49" UHD Tv.
Honestly such Tv has limited life span and 5 yrs old model is quite old and do not have many new features so it is waste of time and $ doing the bracket. Suggest that you wait for it to expire then get another bigger LG Tv or buy a new Tv during sales and use your existing tv in the bedroom.
