Wall mount / bracket question
sharang
Hi guys, it's been a while since I got a new TV. Went to have a look at Courts yesterday and the salesman said that Samsung doesn't provide free wall mount but LG does. Gotta pay $99 for installing samsung TV wall mount - is this true? All along I thought wall mount is included foc, regardless of brands.
daniel_83
Yup they sales too good liao I think
Just bought a Samsung TV last week
Sent from LGE LG-H961N using GAGT
angelazen
Hi all... I have few nos of brand new TV brackets DF600 for sale, which can be used for TV size up to 70"... Please pm me for more details...
jace88
Does anyone know who can remove wall mounts and restore wall eg fill holes and paint to white?
I have two wall mount TVs (40" and 60") which I need to remove as it's a rental property.
hawthorne
U can remove it urself. Wall anchors are a pain remove. The more ex kinds can unscrew. The rest u need to use a chisel and wack the wall till the hole big enough to pry the anchor out. After that u go buy wall putty from hardware store, full the hole and then paint over after the putty dries
winguy
If buy bracket from taobao, any contractor to do installation only and how much? Thanks
Sheldon99
why aren't there any wall mounts that can be height adjustable (lifted and lowered)?
any one?
Stickpudding
Hihi,
My new tv is coming this friday and wanted to mount can i check if they will cover those wires or i need to diy?
nobrain1
Hihi,
if your tv area don't have feature wall to hide cables, u need to diy. just get a small size trunking from handy man shop. Use 3M double side tape to stick, the medium strength or strong one. if u want it very straight, use a water ruler to measure.
ragegoh
Wall mount TV to feature wall
Hello!
I got a wall mount for free from my friend. Both of our TVs are 49 inches.
The TV itself is ard 12-13kg.
I wish to mount it to my feature wall (plywood) for my BTO.
Are there special way of mounting it?
I doubt there is any stud for the feature wall.
dreamer_toons
On the box, it should be stated the weight and the size of the TV the mount can hold. So long as it is within these parameters, it should hold.
When I did my feature wall, I requested my contractor to add in more supports and use a slightly thicker plywood.
I didn't see any studs when the installer is installing the mount; just normal screws. He even assured me that the wood would hold my 55 inches and he did advised customers before not to mount when he feel the wall is lacking supports. So good to check with the installer if you are engaging one, the experienced ones should be able to tell.
ABuNeNe
is there ways to check whether can mount a 43" tv, weighting ~8kg, on a partition wall?
funky05
Anyone to recommend for fixing tv mount? I have the mount.. need someone to drill hole and fix it up on the wall.. no feature wall
petetherock
Moderator
Moderator
Typically the TV companies will do it for you, why not ask the sales rep to get you one?
