Wall mount / bracket question
ABuNeNe
43” tv only 8kg?? Sure?
Yup, see below
petetherock
Moderator
Moderator
My 32" doesn't come with mounting.. so I had to purchase myself
Yes, you would have bought that TV from some company, eg Best Denki or Harvey, they have a lot of contacts for you.
Where you buy the TV mount will also have such contacts..
funky05
i won it in a lucky draw.. it doesn't come with bracket.. so i bought them myself.. just need someone to help me drill holes and mount it on my wall
cloud210
Hi, would like to ask where to buy tv stand?
Used to wall mount but moving to rented place. Don’t want to drill holes. Didn’t get the original TV stand.
Sony 60” TV
Finbias
Sony 60” TV
Try carousel someone might sell stand if they wall mount themselves
Bertrand Traore
Hi all. Will like to check, is it possible to wall mount a 50” tv on a wall between 2 bedrooms? Knock on it and sound relatively hollow (new type of flats). Unsure if its safe enough to hold the weight of the tv and the bracket. Thanks
moron+genius
If wall is partition tat 1 better be careful, normal wall shld b ok. If in doubt better engage installer do 4 u.
McGraw
actually you guys dare to use the screws set provided? or change them to sleeve anchors?
jase07
Looking for wall mount recommendation also. best to have extendable arm.
chengsun
Anyone here has lobang for wall mount service?
I already have the bracket on wall. 32" TV in bedroom spoilt, bought a cheap one 32" as well, need someone to unmount the spoilt one and mount the new one.
Jo1818
32” so small and light, dismount and mount yourself also can.
auzzuro
If I were to get a 55 inch LG tv it comes with the mount but any diff from the LG ez slim mount
DailyRoutine
Question on TV mounting
I'm thinking if mounting up a TV for my study room. But I noticed that my wall has a structured pillar and its not even.
Any idea how can the TV be mounted?
If I mount the TV just beside the pillar using these type of mount, will it work? It looks like I can clear the distance of the pillar and get it pretty center of the wall.
benedium
U probably right that it will work especially with a full motion adjustable tv mount. I used mine with arms slightly extended most of the time anyway. Just make sure the mount can handle the weight of your tv. Usually stated by manufacturer or seller. When I bought my 55inch TV from best denki they arranged for 3rd party tv mount company to provide both the double arm tv mount and the labour to install for only $80 payable on installation. Pricing for your reference but of course it may vary abit. U can find these companies on carousell like tvmountsg or tigermount
