royfrosty
- Jul 23, 2009
I hope you did not buy anything yet.
Most likely you wont be able to fit that long gaming x trio card and the reservoir together.
I meet all the problems when i build a triple rad setup using almost all the same parts that you wanna buy. Except for the gpu im using founders edition 1080ti instead.
Those bitspower rads are actually OEM from hardwarelabs Black Ice Nemesis L series.
You can only go for all slim rads that are not more than 30mm thick.
Cause if you do get a thicker radiator, the top radiator will hit the side radiator, the side radiator will hit the bottom radiator. So go no more than 30mm.
Next thing you will wanna to take note is the inlet and outlet of the radiators. Cause the radiators inlets and outlets will be very crucial with this casing. The bends of tubing and the need of space could potentially be an issue if the inlet and outlet are not in favour.
Best like what shadow84 mentioned. Go for dual 360mm radiator will do. Cause this will definitely be enough to cool all your components.
Your reservoir i suggest, since if you really wanna fit that long gpu, it is best if you can go for this type of reservoir instead.
https://shop.bitspower.com/index.php?route=product/product&path=4&product_id=7134
This will also give you a ddc mount direct to the reservoir. Giving you more space for your long length gpu. It may seems expensive, but it solves a lot more headache as this reservoir can make tubings a LOT more convenient. Look at their installation guide and you will know what i mean.
Dont worry, a ddc pump is more enough for 2x360mm radiators.
As for cpu block, if you go for aesthetics go for same branding cpu blocks, it will complement your gpu blocks very well.
Hope you find it interesting to build wit o11d. Just wanna let you know, trying to fit 3x360mm radiator will be tough, but in reality, go for easier build with 2x360mm and space for your long gpu.
Good luck.
Good luck.
