Not too sure. Just that I remember seeing others recommending it over over brand. That's why checking.
If money is a constraint, go for Toshiba definitely value for money and is 7200rpm
Eh just to double check (with 4 bay nas) that it is possible to put in a single disk.
then buy 2nd disk and setup as raid 1.
then buy 3rd disk but setup a standalone disk.
then buy 4th disk and upgrade to raid 5.
can like that do as u increase the amt of disk over time? will it be complicated or just like a click of button?
thanks
If traditional raid. No. U have to wipe everything off.
Synology has SHR to do such config, other brands not too sure.
yea, i saw people recommending toshiba as well. the warranty is 2 years is it?
shrugs, meaning best to get all drive first and setup the raid at once? instead of getting one by one. else i have to wipe all each time i change the raid config right.![]()
aiyoh, i used 2TB, 3TB, 4TB, 5TB all bo taiji. >2 years.
well, if you getting other brands i not sure so best bet is to set up the raid at once with the hdd ready.
though more or less settled on asustor for now.thanks for the help all along. yea, most of my disk are all working strong after years. not too worried about that.
currently still torn between synology and asustor.though more or less settled on asustor for now.
Read the review seem to be alright now. But dsm still is the best software now on the market.Used to have the asustor as backup for my main synology nas.. my take is the os is laggy and limited addins also the NAS is hotter as compared to Synology.
But they should hv improved after so long i guess
Anyone got any idea?
Sorry to hijack, can I check, I'm looking to get a NAS for home usage, probably to store files and backup. Will also be using together with a HTPC to play movies on TV. Will the budget asustor as1002t be sufficient? does the ram on the NAS matter alot, will the 512mb be sufficient?
The same logic goes for don't buy car, house etc cause all can build yourself. Nas can build yourself and setup but requires much more effort which I don't really wants.
Understand it will be cheaper.
Thanks for the suggestion but I did think about.
Sent from LGE NEXUS 5X using GAGT
dont waste your money. instead of buy a nas, get 2x8tb hdd and mirror in windows. NAS is kinda useless unless u use iscsi provided that your nas have this feature.
if your nas die, u need o buy another similar nas to retrieve your data ( more money). If your windows/pc die, just plug in your hdd to another pc and you can access your data again.
Since I am planning to use the htpc, i suppose transcoding will be done by it right? What kind of apps are you talking about here?
Why not?brother your logic is flawed because technologically you can build a nas but you cant build a car by yourself
absolutely agree![]()
Sorry to tag on this thread. I'm looking to get a synology ds216+. What's the recommended disk brand? I'm thinking raid 1 with 2x1tb.
Was thinking of getting second hand ds216+. Is it still fast enough even though old model?
Sent from LGE LG-H815 using GAGT
I bought the Asustor 3202T few weeks ago. Indeed the NAS is 'hot'. The ventilation and airflow is sub-optimal. My HGST hdds were 51-53 deg C most of the time. Eventually I opened up the case and left it naked, with external USB fan blowing at it. Now the hdd temp is 33-35 deg C. I felt much better lol.
But I like the NAS overall. The ADM works smooth. The HDMI out is useful for direct connection to TV (that's the main reason I went for Asustor, the other factor is the pricing). I still don't know how to use the HTTPS as the cert thingy is confusing to me (I tried but gave up).
