What should I do when purchasing a second hand rig?
dgenex
144hz, 1080p, GTX1070
60hz, 1440p, GTX1070/GTX1080
144hz, 1440p, GTX1080/GTX1080Ti
These are my suggestions, see which fit your budget and needs
Edit: After the slash is if you are playing graphic demanding titles
singupingu
This is true.
Before slash is optimized for price and able to play at medium high to high for most titles.
After slash is the recommended gpu to play high and above for most titles.
Sent from Overpowered Phone Mark III using GAGT
FinalTidus
I am gaming on a gtx 1070 at 1440p at 120hz at Max settings but with AA disabled.
Most modern games can exceed 60fps... With the exception of 1 or 2 unoptimised games which will fall below 60fps at Max settings.
RyanRabu
Hi all, thanks for your time. Just got a 1080 build at pct for $1870. Trying to install win10 now. Should I go with a key from online or Microsoft toolkit?
dgenex
All at your own risk, personally using key from Carousell and working fine.
xtractor
bought@ pay4key.org and already using it 1 yr with the latest update......100% genuine
