When is Mi6 launch?
jeff79
Anybody experienced phone restarting while charging? I experienced 3 times I think.
That was on the earliest rom which charge at full speed while the phone is on and screen off. Later rom removed quickcharge while the phone is on and screen off. All roms still charge at full speed while phone is shut down.
You can check the charging speed by looking at the charging logo beside the battery meter at the top right corner. Lightning logo is normal speed. Qualcomm quickcharge logo which is lighting inside a circle is full speed.
You can use normal 5V2A charge to prevent restart.
Bubbachuck
Is the charger included in the box qualcomm quickcharge? I tried the default charger and a normal charger, both are the same lightning logo only.
jeff79
The charger in the box is quickcharge 3.0. Saw on the miui forum got people posted screenshot with the lightning in circle quickcharge logo.
prawnyhead
thinking of getting xiaomi, but can't decide if i should take MiMix or Mi6. MiMix is older but has the sweet screen, but Mi6 has better tech and CPU.
What you guys think?
redname
Anyone Kenna B4 charge halfway then won't charge Liao?
Mine jus shows charging but the percentage won't move
jeff79
Should be the battery meter bug. When the percentage stop increasing is actually full already. After a reboot will show 100%.
