ZeusTheMighty
- Apr 10, 2013
pls help google store won't install i downloaded apk google store and it won't start!!!
That's unusual.pls help google store won't install i downloaded apk google store and it won't start!!!
That's unusual.
You did OTA or flash?
Tried factory reset?
Sent from Xiaomi MI 6 using GAGT
Ur flash sounds like it went bad...flash and yes factpry reset.
The seller should have posted warranty terms on their sale post?Mine is more than a week old. Ok I'll go back to the shop and ask.
Anyway the dual camera only makes static noises and vibrates incessantly when camera is in use. Sigh.
The original shop ROM is 8.2.0.2version 8.2.2.0 the shop version which has google store doesn't have the flash version every link i went to is dead!
I think I saw someone mentioned the file is posted in XDA.
I need the fast boot version cos it won't update via the normal method and every single fast boot version link doesn't work.![]()
thanks this should be it.The global stable V8.2.2.0 fastboot rom? The link for that fastboot rom from miui server. http://en.miui.com/a-234.html
http://bigota.d.miui.com/V8.2.2.0.N...EC_20170609.0000.00_7.1_global_798f55f46f.tgz
Whewre u orders from bro??Also got my mi anc type-c earphones!
Works with the google pixel and mi5 with lineage OS![]()
Seems there's differing experiences, but mine going from original shop rom and then auto updated overnight by OTA is working perfectly fine.So let me get this straight. The ota update using the shop ROM is ok?
They install not one, but two copies (dual app) of "miui community" app.me 2. OTA no issue from shop rom
