When is Mi6 launch?
kenriku
Shld i cont to use xiaomi.eu or flash to official global rom?
If you're ok with root, magisk, etc then u can stay on EU since I see some ppl prefer it. Or global developer.
If you want to go back to a locked, stock rom, which passes safetynet legitimately, then global would be the only way to go.
I access company stuff on my phone, so I need to observe the rules.
Remember you need to restore even the recovery to stock before u can re-lock ur bootloader.
Sent from Xiaomi MI 6 using GAGT
ZeusTheMighty
I don't see any changes between new global rom and "fake" rom though. :s22:
I experienced a lot of differences
The other 2 roms are China roms and yes one is a global and stable rom officially released by xiaomi but still they have Chinese pop ups and google store isn't on them and for some reason couldn't install google store.
That was a big enough problem for me that i simply said fiak it and reinstalled the shop rom.
ZeusTheMighty
Got this score on 8.2.2.0
Only closed all apps, but services like Whatsapp, etc, still running in background.
Nice...
Did you OC your cpu?
edit: I notice you only have 1 sim card in but i have 2 in my phone you think the number of sims affects the performance? Should i disable 1 sim or put it in airplane mode.
deckcard
When you flash you need to wipe all and not flash one on top of another causing weird problems
jeff79
Antutu is highly sensitive to temperature. Best result is naked phone in freezer.
kenriku
Nope. Not overclocking nor any other mod. My phone is 'stock' from shop. Has Whatsapp, Line, WeChat, Skype, Outlook, Mobile Iron all running in background.
I see posts of 180+ K scores on the even newer China ROMs so mine should not be a big surprise?
I don't know about dual sim, but as a layman it looks like there has to be some system overhead?
