Where To Buy Mobo, Casing, GPU & Help Setup
Pronewbie
Anyway what is done is done already. Lesson learnt for mobo + cpu is still advisable to get from TP.
And fyi if you are getting a full rig, the cpu + mobo on pricelist is not yet finalize.
It still can go lower than that.
My ----> MSI mobo i got $30 off from the list price with a slight bargain.
This. I pressed the trigger too quickly without properly researching on mobos.
royfrosty
ask frosty help u bargain for mobo then
Mobo alone a bit hard cause he got the CPU already. But can try if he is buying more items together with it then it is possible to ask for slightly more attractive discount.
Pronewbie
Frosty I'm buying about 1k worth of stuff,which is more than some Cpu builds. Non reference r9 290 when it's out, mobo and corsair 400r. Also need help to build PC. Don't trust myself to do so with this rig.
GPU: $600 - $650
Mobo: $200
Casing: $100
EatSnakeWarrior
GPU: $600 - $650
Mobo: $200
Casing: $100
computer components damn sturdy one la dont worry
which casing you getting?
Pronewbie
As mentioned, seriously considering Corsair 400R unless there are better cheaper alternatives. Intend to OC my Cpu and run a r9 290 so air cooling will be important.
EatSnakeWarrior
not sure if i asked you before, but have you considered paying slightly more for the corsair carbide 540? probably one of the cases with the best air flow
Pronewbie
Just read up on it and think that it sounds awesome but a bit overkill on my build. I don't intend to crossfire or have a watercooler.
Max budget is Corsair 400r range. Looking for cheaper cos I can't get it online due to shipping cost lol.
EatSnakeWarrior
:s11:
a good casing would last you several builds
Pronewbie
:s11:
Have been reading up a bit more, was on mobile earlier. It looks so pretty in videos lol. Will read up a bit more and decide.. Desktop vs Mid Tower. Any size and heat issues with this case compared to normal Mid towers? Somehow it looks like more heat will get trapped due to lower height (hot air rises).
Will consider this form factor because I'm considering putting my CPU on my table.
Got any kangtao for this?
