Which Brand for Dp 1.4 cable?
Charlie_Zhan
Hi,
Where can I buy vesa certified cables please?
Club3d says theirs is vesa certified
these are all DP/VESA certified HBR3 cables. i am using the one from club3d
https://www.amazon.sg/gp/product/B0767F5DNR/ref=ox_sc_saved_title_2?smid=ARPIJN329XQ0D&psc=1
https://www.amazon.sg/Startech-com-...Q640RYMPK91&psc=1&refRID=1Y1475WSTQ640RYMPK91
https://www.amazon.sg/Accell-1-4-VE...Q640RYMPK91&psc=1&refRID=1Y1475WSTQ640RYMPK91
https://www.amazon.sg/gp/product/B07HL336L2/ref=ox_sc_act_title_1?smid=ARPIJN329XQ0D&psc=1
wait what. i understand if you buy those cheap monitor, they probably won't even give you a dp cable. but if you spend 400+, i'm quite sure the dp they provide is vesa certified :s11:
i bought my monitors from Acer. they gave me both HDMI and DP cables but non of them are VESA certified.
BiG_FisH
So im looking to get DP1.4 cable for 144hz/3440x1440p on my xiaomi ultrawide.
Any recommendations? i searched lazada/shopee and it goes down to
Vention
vs
Ugreen
Even within the own brands also got diff models .
Can share what you gurus look out for when buying these cables
My budget is 20ish
TIA
pardon my noobness, i'm using the included DP cable...any reason to get a new one?
boredscorpia
How do you guys know if it is Vesa certified? I just bought this cable from lazada and I wasn't even aware of this vesa certified thing until I stumbled on this thread :/ if it is not vesa certified I'll return and get a new one
$23.49 | ATZ DisplayPort v1.4 Cable (1.5m / 2m / 3m / 5m) 8K 60Hz 4k 144Hz, DP Cable, DP 1.4 Cable, DP v1.4, DP 1.2, DP v1.2, Ultra High Speed Display port Cable 1.4, Display port 1.4 cable, Displayport Cable
This is the item on lazada
Charlie_Zhan
you can refer to this page for a list of DP certified cables.
https://www.displayport.org/product-category/cables-adaptors/
You don't need VESA Certified Cables unless you want to use
4K @ 120 Hz, UWQHD @ 144 Hz, WQHD @165 Hz, FullHD @ 240 Hz
and your existing Cable cannot do it.
Shutterbox
ralph79
I'm using Dell DP cables and it does its job.
They are going on Carousell around $15-20.
Jurchen King
I just use ATZ cables, works as it should and fast delivery because local stocks
+1 for ATZ cables. Support local :s13:. The price for standard length matches OP's budget as well.
Even though I don't think they are VESA-certified, it's genuine DP 1.4 specification as confirmed by monitor OSD. Your monitor will be able to detect the actual DP specification (and bandwidth).
Charlie_Zhan
TS is trying to run UWQHD @ 144 Hz and has problem doing so.
which is why i recommend him to only buy VESA/DP certified HBR3 cables. which both his options of Vention and Ugreen are not.
purpleberry
Yes ATZ is very good. Next is Ugreen for me. Bought Vention but the casing is not as robust as the others.
Charlie_Zhan
genuine dp1.4 is useless if the cable's bandwidth cannot support the monitor's requirements.
watzup_ken
I think 3440x1440 should be WQHD. Ultra wide should be something like those 49 inch ones.
Charlie_Zhan
nope.. 2560 x 1440p are referred to as WQHD or QHD..
3440 x 1440p and above are considered UWQHD already.
tigerwoods
Vention
vs
Ugreen
My budget is 20ish
TIA
Try the ugreen DP1.4 cable, if can't work just refund.
Gametaku
Aiya don't keep recommend random cable. You will have issue if its not HBR3 Vesa certified even if its from reputable brand.
