Which cable for bookshelf speaker?
The_King
I shortlisted to 2 company.
Blue jean and LHS.
Any advise, which have better connector, cable, connection etc... Matching dollar or dollar?
Say 200,
Blue Jean = cable +shipping = 200
LHS = cable + $6 bus transport = $200
yves
Blue jean and LHS.
Say 200,
QED, Van Den Hul, Supra, Chord are good choice.
yves
thanks for sharing, i take a look
They all sounded better than the usual bluejean which are likely made of belden and the usual offering at LHS which sell belden and canare.
yves
You can find them in shopee. But looks for shop from Singapore. Else you can get used one from Carousel.
petetherock
Moderator
Moderator
1 - be careful of what you buy on shoppee and check it's authencity
2- spend roughly 10% of the total cost of your system on cables, if you have an entry level system there's no point pouring hundreds in and vice versa
3- the room acoustics, the quality of the power supply can play more important roles than changing cables
4- buy 2nd hand to save
The_King
thanks WTF so expensive
my speaker is either diamond 12.1 or es15 for near field
yves
Used Kimble, QED ,and most high-end speaker cables are at least 50% off or more from new.
But don't overspend on cable since Diamond 12.1 is low-end speaker, you can't hear much different.
The_King
thanks let me search for used brand cable, it cannot then i get from lhs
thank fors haring
galapogos
Moderator
Moderator
This. Just get the required AWG for the speaker wire run you intend to have. If you're feeling fancy, get OFC. The rest doesn't really matter. I got a spool from Amazon for cheap when I was setting up a few years ago.
dreamaurora
Many good recommendations here.
I started my audiophile journey with humble cheapo Monoprice speaker cables from Amazon.
Then after that went to LHS and got Belden Studio 814 from them. It's the most expensive DIY speaker cable available from Belden and rare to find. Thankfully LHS has a spool. Improvement was not subtle, and everything was immediately richer, bigger, and more detailed.
Then I got Nanotec #79 MK2 from Horizon Acoustics (think they still have), very good DIY speaker cable also, less thick sound and more liquid vocal.
So these two are my recommendations if you want good sound from your speaker cable at very reasonable price. You can get Studio 814 easily second hand from Carousel.
My two current pairs of speaker cables are high-end 4-digit speaker cables. Yes, you do get what you pay for speaker cables.
yapks
Which speaker cables are you using? I'm looking for a more affordable pair for my third setup, hoping that something interesting will appear on the secondhand market. I prefer a tonally livelier type; neutrality is not a concern.
petetherock
Moderator
Moderator
Everyone should state their setup when talking about how much improvement cables make.
I spend a few hundreds dollars on the cables used for my Dynaudio Platinum Confidence bookshelf speakers and it’s been a blast
YMMV
dreamaurora
I am using Ricable Invictus Reference for my main setup and Acrolink Mexcel S-9000 for my secondary setup. Both these pairs are very refined and smooth sounding speaker cable.
yapks
I'm familiar with Acrolink. I have 7N-S8000 speaker cables and still keep a full set of interconnects and power cords, although I no longer use them because I have developed a different taste. Acrolink is too smooth for me, and I now prefer a more exciting sonic character. I'm just curious about your cable strategy. Do you use a full loom to maintain consistency or mix and match to tune the sound?
