window problem
Survivelater
Hi,
I am facing this problem with my parent PC.
Which when i on the PC, after BOIS stuff it when in to black screen even before window logo. how should i solve it?
past few day my parent told me about this problem above and ytd i able to on it and boot to window 7 and i went ahead to update to window 10 and once it restart the PC, the problem appear again. so i am confuse whether my PC is still in window 7 or window 10?
the solution i found online is to repair the window with bootable usb but the thing is i am confuse to use window 7 or window 10?
Koenig168
It is probably not a Windows problem.
Try re-seating your GPU and RAM first.
Koenig168
but theres no beep sound or anything sound so i assume is window problem...
what do you mean by re seating?
Take out the RAM and GPU, clean the gold contacts and insert back. Power on.
If problem persist, wiggle the RAMs a bit and try again.
