thumbtacked
battery life is very short.
How short in real life usage? Specs say 4 hours
I actually really like the outlier air. But until I can find a fitting right eartip for proper seal I won't be 100% satisfied.
animeonegai
Ok. Got the Amoi F9 touch 5.0 . Supports up to AAC codec.
Sound wise, i think its lower sound than creative outlier air. Sound stage not as wide. There is a certain abnormal boom sound if play a heavy bass music. Could be the codec. Not sure. Will need to try again.
Lasts 5 to 6 hours (in manual).
Touch is sensitive.
The best part about the earbud is that the case allows 1A charge. It has 3500mah capacity.
I think left sound is not as loud as the right. :(
WhiteHunter
usually 3-4 hours. the case can give another 7 hours. not really alot compared to others.
ckfreeblue
Returned it cause I couldn’t get a proper seal.
j_tan89
Sennheiser mtw qoo10 $349 can buy? Says 2 years international warranty?
If you check if them, they will say that for warranty it is shop warranty. Means you have to return to them. Not very safe imo
bratpig
Oooo...thanks for the enlightenment
Let me think deeply over this and mw07
I'll be getting my car back from workshop next week. Usage will be limited thereafter
Dunno whether to take the plunge
Sent from Samsung SM-N960F using GAGT
thumbtacked
Actually more important to me is authenticity.
As long as genuine product I don't mind forgoing warranty for a lesser price.
xuan87
Anyone ordered from taobao? Its taking very long for my orders to come. Ordered one since before cny. They only start ship on 10 feb. Until now, it says in sg but no indicative of where.
talk to their CS and send them a reminder. it happened to me before, after you tell them the item will mysteriously be delivered a couple days later.
mr168
have not seen much local reviews on anker soundcore liberty air. i just bought this and found the connection to be quite decent. no sudden disconnection between my phone and the earbuds. in fact, i have just returned creative outlier air after just 1 day as i realised it is quite buggy and finishing is worst than those $30 china brand earbuds.
Jlyong0008
Quite a few reviews online about the Anker. I'm using them. The only time I had issues with connection was when I walked around the IT Show recently. Too much interference on the show floor I guess.
limjialok
Any recommendations for budget earbuds at under $50 with at least 3hrs of music time and doesn't audio lag when streaming yourube videos?
Jonathan Emmy Switcher
Wf-1000x sounds great. Only gripes is the latency. It's possibly not suitable for playing games and watching movies.
Battery life isn't great. Rated at 3 hours. Casing is bulky.
The disconnection between left and right does happen once in a while. There was also a few times when only the left earbud has audio but offing and on it solved the problem.
If your main use case is to listen to music on the way to work and maybe in gym, it's a great earbud.
wizardmao
any reviews for beoplay e8, any distortion on bus scanner.. drop outs etc..
No distortions on bus scanner or those retail stores security scanners from my experience.
Been using my e8(first gen) since jan 2018.
Wont drop out if you dont shake and swing your head like crazy. Otherwise will. I use it for casual lifestyle use and not sports so no issue.
Sound is pretty decent and subjective so best to test it yourself.
No audio lag between left and right and when watching video e.g. youtube from phone.
Some people might not like its design and fit. For me its alright. Still best to test for yourself.
