kryptonit3
great ! thanks good to hear that .. ;)
No distortions on bus scanner or those retail stores security scanners from my experience.
Been using my e8(first gen) since jan 2018.
Wont drop out if you dont shake and swing your head like crazy. Otherwise will. I use it for casual lifestyle use and not sports so no issue.
Sound is pretty decent and subjective so best to test it yourself.
No audio lag between left and right and when watching video e.g. youtube from phone.
Some people might not like its design and fit. For me its alright. Still best to test for yourself.
thumbtacked
Does the audio lag while watching videos/YouTube/gaming?
wizardmao
My post already told you no audio lag when watching on youtube. I tested this at stereo before my purchase.
I dont know about gaming since i dont game on my phone. I believe it shouldnt make a difference.
thumbtacked
Alright thanks, will check it out
Jason8811
This is very very gd, tested it this afternoon. Probably the best sounding true wireless I've tested (to my ears) so far, 10hrs battery life, no signs of lag when tested with youtube on my phone, connection was strong so far I've used till I reached home. Most importantly, although its not as cheap as the creative but at $200+ it's the best value for money true wireless for built, sound and battery life.
DigDub
Got the nuarl nt01ax as well. Sounds balanced. Most important is can control volume also and the led doesn't vlonk annoyingly when in use.
uplorry
Suspended
I also got my NT01AX yesterday evening. Sound is spot on and connection is great. Fit is great with the stock tips as I couldn't get a good seal with the CP350. For the price it's a no brainer when compared to other more expensive options.
The Outlier Air I ordered way earlier is nowhere to be seen though...
DigDub
how’s the fitting like.
Quite comfy for my ears, no pain point anywhere so far. I removed the fins though as I find they block the earbuds from sealing with my ear canal. The earbuds themselves are quite big, so you can head down to Stereo to try first.
DigDub
The cp350 seems oval in shape? I had to rotate it to find a good seal for my ears.
uplorry
Suspended
It is oval when attached to the bore. Quite weird I would say. I tried turning in all directions but it doesn't sit well in my ears.
I'm using the regular medium black tips now with small wings.
DigDub
Ya, it's oval only when attached, strange.
uplorry
Suspended
I can't seem to figure out how it works... But maybe I'll revisit them after some time. I heard they take some getting used to as they have a shallower insertion. But they're sort of the overall best tips for true wireless right now.
