BlackRozeInc
May I know can connect to Iphone or Android phones ?
Any lag when watching movies.
I dont use iphone so i can't say but it should work. I connected it with my Xperia mobile and was working fine. Music was great, no detectable lag when using Netflix, Youtube, or a 3rd party anime app. I enabled AptX on my phone fyi.
I didnt try the Momentums as they were over budget and i didnt want to make a mistake that ill regret if i were to try them on. Was also tempted to try the Audio-Technica but also way above budget.
thumbtacked
Retail shops in JB have liao. The week before last i went paradigm mall's Samsung shop and ask. They have it at 499RM but only in white. I was looking for yellow and they say other colours only launching end March.
Just get from carousell. Everyone selling $180.
thumbtacked
Did you do a gaming test?
Viren_S
Was the NT01L also available for testing?
BlackRozeInc
That was available and i did test it out. As a budget option, it was also one which i had considered. But when tested, to me personally, it sounded flat and weak, somewhat similar to the jaybird run xt. My ears just didnt like it.
Viren_S
Oh I see
What were the other budget options available
Spongebob79
Hello, need some recommendations...
My Bose soundsport ( not fully wireless ) is giving me battery problem. I tried AirPod v2 but I do not like the sound quality. The Bose Free seem to have a lot of connectivity issues, so I need so some recommendations for for a good sound quality pair but budget ard $200+. Pairing with iPhone and iPad.
Thanks in advance.
doki81
Thanks in advance.
jabra elite 65t...heard nuarl not bad too
Sent from Samsung Exploding Not 9? using GAGT
BlackRozeInc
Oh I see
Personally I'm not sure as I only looked at the Nuarl NT01L, but Stereo has a few options.. You can look them up on their site..
Thanks in advance.
For sub-250 SGD, you can go for Nuarl and Jabra. I've also heard good things about the Creative Outlier Air, seems to punch above its price point. Downside is that there is no way to test the Outlier unless you have a friend who already has it, and only comes with 2 pairs of eartips with no aftermarket options.
musicsg_com
I'm currently reviewing Mavin Air-X. I compared to RHA TrueConnect and find the Mavin is more balanced. Bass is not too excessive, treble is not too bright. What I like is the Mavin Air-X delivers detailed highs with sufficient transparency and precision for TWE. There is a little grain in the treble but doesn't sound like transmission issues.
Mavin Air-X supports Qualcomm TrueWireless and aptX, delivery is clear. I tested on Huawei P20 Pro which does not support TrueWireless mode but it supports aptX.
Comes with silicone jacket to get better grip when using it for runs. I like to keep it permanent to protect the glossy body.
Retails at S$249.
Viren_S
Retails at S$249.
Any recommendations for below 150
v1hypersg
anyone can share their experience of using the RHA TrueConnect ?
my erato 7 is getting on my nerves, use once and then put back into the case to charge and not after long, battery low again, it has been 1 year already,
thinking to get the RHA TrueConnect but hope to hear some feedback,
it seems good on the internet review but hope someone can share their experience
ZergRush
Using my Nuarl for a few days. Need to manage my expectations as wireless really cannot compare with wired.
SQ wise i find my Nuarl is good but not great. If want great SQ must go wired.
But the freedom and ease of using is really different experience.
Nt10ax connects flawlessly every time. The fit is really impressive, with the spin fits.
BlackRozeInc
There will always be degradation with wireless be it networking, gaming peripherals, etc. Audio is no difference. But convenience comes with a price. But the SQ of wireless isnt too bad if you get the correct buds.
queerquirks
Any recommendations with good voice call quality? Below 150, leaning towards balanced sound sig
Sent from Google PIXEL 2 XL using GAGT
ZergRush
It's either cheaper Chinese products or $200+ for the more popular models. Maybe up your budget a bit and get the popular models
