DigDub
- May 21, 2002
Ok ba, the size like typical bean shaped tws earbuds. Bose ones then look like Frankenstein.
Bass on the SABBAT e12 is more boomy but more tight and controlled on Mifo O5. The size and fit of Mifo O5 is also better due to it being smaller in size. Build quality is also better on the Mifo O5 with it being metal instead of glossy plastic on the SABBAT e12. Default eartip was used on both. No connection issue encountered on both earbuds. The "lady" speaking("connected") whenever i remove the earbud from the case is better on the Mifo O5 in the sense that the English is articulated better.
Sent from Samsung SM-G975F using GAGT
Anybody tried both Nuarl nt01ax and Sony wf1000xm3? Which is better in your opinion?
Also, does anyone find the nuarl way too loud? Tested at stereo today and found it way too loud even at the first volume. Am using iOS by the way.
I have both. Nothing beats the Sony in terms of sound quality in my opinion.
Do u find the nuarl to be too loud? the first volume on my iPhone was way too loud for me.
Nope, the volume is normal on my Android phone.
Thank you. Will look that up
Mpow T5 can get below $50, create a new account - $5 and shop voucher - 2.
t5 lo.
Lazada selling
Sent from Google PIXEL 2 XL using GAGT
there's one $54, seller luckyextraWhich seller u hoot from?
Got comparison of mpow t5 to mifo o5?
can go jogging? will slip out ma?![]()
