PiPiChew
can anyone advice on sennheiser momentum true wireless?
feel like hooting but the price tag is....:eek::eek:
Qoo10
$469 - $40 off official Sennheiser store - $30 off (min $200 spending) = $399.
If you want to save more use those smlj qcoin that i don't bother one.
Sent from A Young Urban Professional With At Least 3 Companies Going After Him - Utility, Telco And Credit Cards using GAGT
Exia14
GPGT. Through the recommendation of previous post, hooted a KZ T1 (S$60). ******* happy myself, was unhappy using a X-mini, tried 1000xm3 and other TWS but I think my ear noob, because this T1 really sounded like Sony 1000xm but with more forward vocals and just a slightly wider soundstage comparatively. Bass was loose but not terrible, details are not overlapped and eq felt controlled.
Overall really liked its quality for the price I paid, but in fair comparison only on SOUND pitted against other wired IEMs/headphones/ BT wireless/ TWS. I would give this a 6.5/10, ignoring price and other build quality blah blah.
(for references: Sony 1000xm3 was 5/10 for me, Vsonic GR07 was 8.5/10)
Foam sounded better but the original KZ foams was too big to fit back into the case, have to stick with the stock tips for now. Quality and feel is very good, except was puzzled they chose to have micro usb instead of usb-c with many competitors having the latter.
Bought the +$2 option for a dual drive IEM and KZ foams
Snug fit with stock rubber tips, but checkout the foam tip on following pic
Foam tips doesn't fit that well. Hope they come up with a customised tip for T1
Hopefully someone can compare it with other legendary budget TWS too (mifo, Sabbat E12, etc)
Quick update:
Manual actually mentioned about burning-in the earphones for about 3-5 days to get better sound (meaning 72hours and above to achieve the best state?)
So take my piece with a pinch of salt.
GPGT. Through the recommendation of previous post, hooted a KZ T1 (S$60). ******* happy myself, was unhappy using a X-mini, tried 1000xm3 and other TWS but I think my ear noob, because this T1 really sounded like Sony 1000xm but with more forward vocals and just a slightly wider soundstage comparatively. Foam sounded better but the original KZ foams was too big to fit back into the case, have to stick with the stock tips for now. Quality and feel is very good, except was puzzled they chose to have micro usb instead of usb-c with many competitors having the latter.
so that you can buy another kZ again
theaudioguy
Totally agree. Connection drops sometimes too. Was a user before but sold off 😂
Got try at those headphone stores like Stereo and Connect-IT? I personally feel it's not worth the price and battery life is quite short. If you die die want it, I saw Popular at bras basah got promo, $399.
Alexz_Hong
Quick update:
wah wah wah. haha. was tempted to hoot, but the battery life was a bit worrying for me. haha. do share what type of battery life you're getting? haha. TIA
lDuckRicel
Oh yes, the battery drain issue. think I need to reselect, I had already tried it in Stereo before liao, the sound is astonishing...:eek::eek:
lDuckRicel
Qoo10
Thanks, I think I reselect another one. This one got battery drain issue.
lDuckRicel
just went stereo in plaza sing and pre ordered sony wf1000xm3 black.....:s13::s13:
shinoku2
Thinking to get comply ear tips for my pamu slide and sabbat E12 anyone using them ?which ear tips will fit for them?
DigDub
The seller whom I bought my mpow t5 has another set to let go. Can contact him on carousell if interested. :)
sansanjikikut
is the mpow t5 good for voice calls?
any wireless compact ear buds to intro? bluetooth signal and voice quality/clarity is of utmost importance. mostly used for making/receive calls only...
