Cheese Steak
- Oct 25, 2010
Should i just whack the te-d01g or wait for the te-bd21f? saw that these are the first multi driver truly wireless earphones.
just whacked the aviot te-d01g for $159, hopefully i wont cancel the order and get the klipsch t5 instead.
Anyone came across true wireless earphone that are NOT in-ear type? . Similar to AirPods .
urbanista stockholm,ticpods but then most ppl get other true wireless earbuds for the in ear performace. if u dw something thats in ear airpods will be a great choice due to the excellent connectivity.
Sabbat x12 Pro.Anyone came across true wireless earphone that are NOT in-ear type? . Similar to AirPods .
Suggest you get airpod, I had sabbat x12 and airpod, airpod has better sq and connects to iphone faster and most convenient.Thanks. This is interesting. Haven't came across these until you mentioned. Yup, i may end up getting the airpods. Just want the wireless convenience without shoving stuff into the ear canal.
mpow t5 vs kz t1, which one would sound closer to shure se215?
anyone could share some insight?
are these 2 right now the most bang for buck tws?![]()
Kz t1 battery life like quite bad, 2+ hours only?
Can charge during work mawah 2+ hours quite bad ah..
commute from home to work, work to home.. then ki chia liao
but as of sound quality leh? how is it comparable to an IEM ah? i'm using shure se215 now
