rerear
Where to hoot E12 pro that have single color body? Not the ones with black in middle.
Alexz_Hong
I worry more of those functional durability.. scare later 3 months light use den 1 side up lorry..
That's what happen to my airdots..upon opening up.. the airdots wiring quite cui.. a bit jiu short circuit..
This one no idea already. lol. have to ask those who has been using both models longer. My mifo O5 is around 2-3 months old i think. pass to my sister to use, still going strong.
Saw online ..
Audio and video latency for mpow T5 is not very good..
On the other hand mifo o5 have close to no lag..
Able to confirm that ?
This one depends. All wireless earbuds will have more latency than wired. Qualcomm has something called aptx LL (low latency), but very very few earbuds have that, and they're mostly very pricey (Sennheiser MOMENTUM), AND you need a compatible device too.
For audio/video sync, it's app dependant already. Like youtube, netflix, for example will sync them up. It's not a perfect sync and if you are very particular you can notice it still, or like a simple video like this. Both performs about the same to me actually.
But for games, the audio feedback delay is very obvious for both, since they can't do A/V sync for your sudden inputs, etc.
I am interested to get either the MPOW T5 or Mifo O5.
Can I check how is the microphone or call quality for these 2 models?
Thanks
Both are not that great, but to me the Mpow T5 sounds better. This is for quieter environments though, in noisier environment both are not good for calls. maybe if you speak really loud? haha. :s13:
AlwaysHardAlwaysReady
Is mifo o5 or mpow T5 have on par sound quality wit jabra 65T?
If there are no good promotion tis comex 2019.. I just gonna hoot mifo for the good fit..
Used my gf havit G1 pro.. find the sound quality is quite ok for me..
Alexz_Hong
this one wait for others to comment ba. never tried the jabras before. :s13:
ksksksks
Almost as good.
It is always best that u find a earbuds that fit your ears well. Some earbuds can cause ear fatigue over time if fit is not right. Very obvious when I switch over to the AirPods.
Computeron
suddenly i also wonder how gd is jabras.. alot of ppl wearing it.
even gals... is like gal so anal about sound till must buy jabras? not cheap wor.
:s13: my wife, to her got acceptable sound can liao.
Alexz_Hong
wah. i see that frequency response for the sabbat e12 for treble a bit worrying... haha. anyway, more interesting comparison is with the creative outlier air. Sound seems better than jabras?
Some people maybe like the design or what ba. With audio also get diminishing returns as you go up the price ladder one. To me because of the life span of these earbuds, the audio source I'm using, I don't really feel the need to invest too much in it even though I want good sound. We're at a point where plenty of TWS earbuds can do that liao.
I remember when I tested the iconx 3 years ago. Though i love the design of TWS because it's better for jogging, the battery life and sound quality still behind the jaybirds of that time. Like 1.5 hours use per charge if play music from my phone is just :s22: Thankfully things got better really quickly. :s13:
Computeron
i have tried the creative outlier gold.. to me.. i dont like it, not my type... i would'nt pay that price for it.
compared to my current kz zsn bluetooth cable.. is like no fight.. even KZ t1 is better
well... just me..
Alexz_Hong
well... just me..
:s13: cannot compare to those ba. with bluetooth cable is still considered over the neck one. Even for TRN BT20 adapter type will probably still sound better too. Just that the ease of use not there, especially for me my main use is jogging.
KZ T1 is one of the better sounding TWS i've tried in this price range liao, but it still feels quite rough around the edges in some areas. Then the volume jumping is the one that really annoys me. Can't get the volume level that I want. If not i'll probably just keep using that liao. But for outlier air I would be willing to pay that price for it though the jump from mpow t5/m5 to outlier air is not massive, i still think it sounds a bit more.... refined? haha. can't think of a better word now.
Jxoppa
I received my redmi airdots and it sounded so good for the price. Good noice isolation, easy pairing with phone, clear vocals and decent bass. Totally value for money
Computeron
wa... u sounds like the tws si bei god like.
morkutao
MPOW t5/M5 finally arrived. Sound quality wise, mpow wins hands down. I have the Mifo O5 Pro btw. Mpows has basically better sound across the range. brighter highs, more forward mids, and better bass. The volume also seems to be able to go much higher. Aptx support is nice too of course. Mic quality is one of the better ones i've tested too for this type of design. The button is also nicer to use on the mpow if that's a concern for you.
But fitting wise i think the Mifo O5's fit is better still. Then in terms of the design, packaging, case, etc Mifo wins hands down. Metal case feels super solid, etc. Mpow looks like just another pair of nondescript cheap earbuds with a cheap feeling faux leather cover. lol.
Battery life can't say just yet in terms of single charge use, but should be about the same based on their rating. Overall battery life definitely Mifo O5 wins.
to add on.. i actually think mpow t5's battery life quite solid or maybe i have a low usage,
i used it daily whilst commuting to and fro work journey ~ 30mins.. + in office use 1-2 hours, last me 1-1.5 week before i full charge the case again
daniel_83
i have been using Jabra 65t since launch (1year+ ago) and did some readup online recently and seems it is still 1 of the best out there
i like how it sits nicely in my ear.
everyday on the mrt i see many other funny brands with blinking LEDs or bulky size.
Some people also wear it wrongly... like it's going to drop out anytime
but the 65t has 1 problem; the ezlink card readers on buses will create distortions and cut-offs
i think other brands/models dont have this issue? because Jabra is using near field magnetic induction
daniel_83
if i need to buy one now, i guess i will still buy a 65t (carousell has lots of sellers) or a Samsung Galaxy Buds
I dont like the E8 touch controls or the momentum's reflective looks
Alexz_Hong
Bo liao dug out my old Jaybird X2. still working, but the cable already fraying with exposed wiring. haha. Forgot how nice those sounded. I think maybe still slightly better than the creative outlier air. :s13: makes me a bit tempted to try the vistas. but so expensive :(
ksksksks
65t can’t use between cabins in the train and those extended bus
