benzene
Finally manage to get my hands to Jaybird Vista.
I really like it a lot.
The sound is good and the fitting is great.
Connection wise i dont have any issue with it.
From Krisshop, i paid 251
UVERtainment
Can I jus check will the charging case constantly drain itself even when the earbuds are not in used?
Does it work in a similar way like a laptop battery? If untouched for a long period, battery will drop to 0%
davidwong
It’s multiple issues
1st windows at its current form not the best experience with Bluetooth headset
Bluetooth 4.x vs true 5.0
Master / slave (L/R) vs multiple masters
Codec used
Your Bluetooth dongle location and also are you near any wifi to 2.4G wireless devices / dongle
My QCY T1C also have problem when connect to laptop
1 side connect to laptop, 1 side to phone
Posted from PCWX using ONEPLUS A5010
gong318
depressing day, lost the left bud of my mifo o5. Lucky can still use right side for running..
Sent from OnePlus GM1910 using GAGT
meet_nanda
Is it still worth to get Sony WI-1000x compared to the latest ones (be it neckband or True Wireless)? Main priority is sound quality.
ksksksks
Still the best fitting earbuds. The ultra model does sound better on one plus 7 pro vs the non ultra model. Some reviews online have said connectivity has improved as well
tohchr
Bro, can share the link which online shop u get it from? I wanna buy as well. Thank u!
laeticia
Hey could I trouble you to measure the size of the black ear buds on the bottom row? They were the perfect fit for me and I'm now trying to find a similar pair to use with Mpow M5 which hurts my ears.
My Sabbat was returned to seller for refund :s13:
ksksksks
About 1.3cm for the bottom diameter
