ksksksks
Correct. But if no activities from phone for few minutes it will off itself.
Err not trying to sound funny, but, putting on the desk after removing from listening, it will still play right? Correct me if i'm wrong?
Yes, after using it, i put it into the case right away, and now, i noticed that the 4 white LED on the case has gone. :)
Thanks!
frizee
Ahh ok bro, so you're saying, in the event without charging case, after im done listening, pause the music on the phone, then leave the headset on the desk, and after a while it'll auto off/sleep, right? :)
Audiology93
Which wireless earbuds are comfy for long usage? Preferably not airpods
Galazy bud and Mifo O5.
Yep. If there's no music playing, it will switch off by itself after a while.
Sent from Samsung SM-N970F using GAGT
vofzxy
can i ask for some help please?
i tried to reset my nuarls in the case, then it turns one 1 side is flashing white non stop
the other is white always but less bright... is that right?
is this pairing mode?
in this state, my p30 pro cant seem to detect the nuarls
chesterqw
size comparison, the battery is AA
jabra elite sports, creative outlier air, lypertek tevi, x-mini liberty xoundpods
C32B
With so many ear buds out there, any recommendation for one budget below $100 with microphone for phone use ?
Sent from OnePlus GM1910 using GAGT
daniel_83
Just realise Jabra 75t is coming out in Nov
Smaller case and magnetic
Small earbuds with shorter mic
7.5hours battery life, crazy!
Sent from Samsung SM-G975F using GAGT
quekky
For Mpow M5, do you pair with left side or right side? Or izzit possible to pair with both side at the same time?
I notice that it always cut off at Seragoon Circle line escalator (going down to the trains that 1)
rerear
E12 ultra, right side keeps getting itself unpaired, maybe because i seldom put it back into case after using, only individually power them off. Watched all the videos on re-pairing but only sometimes can work. Any expert here? Hope can re-pair without needing the case.
ksksksks
You can try getting the earbuds back on by holding onto both sides
