DigDub
Hi DigDub, mind comparing the Melomania 1 with the Galaxy Buds¿ Many thanks on advance.
Melomania 1 has more mid bass than galaxy buds. Galaxy buds sounds brighter. Melomania 1 has a really smooth sound but doesn't sacrifice the highs.
beary2teddy
i recently bought the e12 ultra, but the right earbud can't seem to pair. anyone with similar issue?
JackDulouz
Tevi's connectivity is pretty bad.. Starts breaking up during a visit to the hawker center
:s22:
davidwong
Yes bro I don’t have it I also heard so much Good on the sound bar ppl has commented on the fit (which is similar to my earfun free which is not that comfortable) and also one side keep failing
tried Creative Outlier Air, the sound sounds good. Does anyone have reviews on that? I haven't purchase yet
justln
Read the Creative Outlier thread here, a few people got ear infection from the bad fit/material. :eek:
pspcrazy
Go down to plaza sing mojito shop to purchase the Jabra 65t elite sport earbuds for a set of 3 pairs of different size S,M,L at $8. They fit the outlier air perfectly
pspcrazy
I now replacing my outlier air with airpod pro and exchange another of my outlier air gold with my fren with gshock kings
chesterqw
Samsung gaxlaxy buds. No delay on YouTube and Netflix.
Sent from Google PIXEL XL using GAGT
There should be no delay because those apps will compensate for the latency.
You want see got lag or not, just use them with games.
chesterqw
The outlier air isn't that great so a lot of earphones would be an upgrade, even the airpod pros.
G-Shock is good.
Also idk why you bothered posting, idk why I bothered replying.
kryptonit3
anyone owns the melomania 1 managed to get their hands on their official silicon case and where to get them?
Audiology93
Hmm I tested it on clash Royale, no delay either. Haven't try other games.
Sent from Xiaomi MI 9T PRO using GAGT
Morugana
Your good and reliable expensive elite 75t will only last you 6 month until the battery degrade till left 1 hour per charge.
While i can afford to buy and throw my cheap earbud every month. Just because I can.
Can't wait for Elite 75T to drop. Compare such brands to a host of crappy cheaper earbuds out there I don't get why people won't just invest one time in a good and reliable one instead of buying a cheap one and then regretting and looking out for another replacement.
