Sheldon3
Sound is bright. Bass is not very strong but it is there
oh, what kind of genre is best suited for the tevi? Also, can i hear others talking? on my zolo liberty, it is only close to max volume only then i cant hear outside noise. Also i assume the bass part can be tweaked with an equalizer app?
ksksksks
I play edm and pop. The bass level can get me going and pumped for my run but a friend who is very into bass and gotten e12 ultra says that the tevi CMI :s13:
It fits and sealed up on my ears very well. This is quite subjective. The buttons on the buds r bit hard to press. Equaliser app not available yet.. it is wip still
Sheldon3
great! leaning towards the tevi too. Also i read that the connection is separated to each bud meaning i can listen to either side with the other being inside the case?
dominicwor2
What would be the best choice if my priority is sound quality? Batt life not so impt to me if need to compromise
DigDub
Depends on what sound signature you like. I'm loving the Cambridge Audio Melomania 1, it has a smooth sound signature.
ksksksks
Yes all the audiophiles are saying MTW is the only piece that gives u the best sound.
Hope they can come out with another version with better battery life :D
JackDulouz
:D
And ANC, wireless charging..
Posted from PCWX using Pixel 4 XL
wizardmao
My E8 still working well since Jan 2018.
Next upgrade would probably either be the Sennheiser MTW or if the Google Pixel Buds 2 can offer some nice features (since I have P2XL and P4XL).
