marxace
Melomania has a smoother and warmer sound compared to galaxy buds. The galaxy buds has an elevated treble which gives the impression of clearer and more exciting sound. The Melomania has a flatter treble and warmer mid bass, which gives a mellow and smooth sound without sacrificing details, the top end and mids sounds very even.
The case comparison below. The Melomania case is the smallest I've seen, comparable to airpods case.
Thanks for your comments and the pics.. i feel buds case v compact already. seems melomania one even better.. just sian that its micro usb
DigDub
Yup, the Melomania case is thinner, so put in pocket won't have a bulge like the Samsung case. I guess a usb-c port will make the case bigger?
anthonygreenisreal
I got the Lypertek Tevi during the flash deal for 88 dollars. The hype is real. The sound is one of the cleanest I have heard for a TWS. The bass is actually there but it’s just not the boomy kind. It’s more of a thump instead. It doesn’t distort even when going loud. The most impressive thing is how it is able to present various instruments back and front. For 88 dollars it’s more than worth it. I intended to use it for the gym but now I think the Jabra 65T active will be for gym instead.
Sheldon3
just received the tevi! the sound is very crisp but bass is lil lacking. The case comes scented too :)
bohemian rhapsody sounds so good with this
P.s anyone knows where i can buy the foam tips?
ksksksks
It is indeed very impressive when I first got it. Now LP2 sq is on another level but if it is lighter. Would be very perfect.
ksksksks
Comply true grip doesn’t seem to fit. Can fit the sennheisser mtw tho
ksksksks
:s13: yes doesn’t fit at all
But quite impressed with these foam. See reviews say will wear off after months of use. Mine so far so good, about 5-6 months in.
Enjoy your tevi :flash:
It barely fits... Worried about the lifespan of these things tho but there is an improvement using the foam compared the silicon tips
jervislim
Comply T200 fits. Earbud still can sit nicely into the charging case after that.
Rated R Edge
Holy fk the flash deal went at $88??????????? :eek::eek::eek::eek:
jujube
Any recommendation for movie watching?
Sent from Sent With a PC using GAGT
garychengjw
Same feeling here. I find it excellent on vocals.
Sent from Google PIXEL 4 XL ~Oh So Orange~ using GAGT
anthonygreenisreal
Yeah man. The look is not my favourite but the sound, features and functions makes up for it. At least it doesn't look as ridiculous as Bose Soundsport Free. As someone who uses the Etymotic ER4s, I can say the clarity of the Lypertek is really quite good. Going to test out the sound in public places later.
DigDub
Took out my mpow t5 to listen after a while. Still amazed at how good it sounds.
