ksksksks
Lypertek tevi works really well on iphone. Hope got flash deal again so it will be below ur Budget =:p
hi all!
hoping to score a good deal in time for this black friday.
what wireless bluetooth earphones would you guys recommend for a budget of $100-$150?
will mainly use for netflix/YT videos on my iphone7. spotify too, but video-watching is my priority.
am currently torn between creative outlier air and x4 jaybird.
what do you think about these 2? any other recommendations?
thanks in advance!
DigDub
New hoot. Using on Android phone. Most functions can work. Put one side back into the case the other side in the ear still can work. Proximity sensor and assistant don't work, I don't use them anyway. Went to a electronics shop to use their demo iPhone to enable the Off option for noise cancelling. Lol. So far quite happy with it.
tohchr
I am using this as well. The comfort is top notch out of all the wireless earphones which I owned. Mainly used the passthru mode and I find it sound much more natural than Sony XM3. I used this from morning till evening off work, once reached home, will switch to LP2.
ksksksks
Same here the Liberty pro 2 and AirPods pro. for the last few weeks =:p
DigDub
I find xm3 sound still the best. :o
tohchr
Yes, xm3 sound is better. I'm referring to the passthru where we hear the surrounding sound, APP sound more realistic than xm3. Xm3 passthru doesn't sound natural to me.
DigDub
Oh ya, APP passthrough sounds very natural, but I seldom use passthrough.
tohchr
Haha. I use passthru all the time as people always came looking for me. That's why I can tell between APP and xm3 passthru quality.
gong318
Nope. You lose USB type C and wireless charging. No point changing unless your E12 Ultra spoil.
Sent from LG G7 ThinQ using GAGT
btw how is the seal on mpow t5, I find the sabbat's seal not too spectacular
Sent from OnePlus GM1910 using GAGT
mufasa
I am planning to get Airdots <$60 for my casual 30mins run, once a week.
Or any other good model to consider/recommend?
kazuki666
Just received awei t10c. For a low price, nothing to scream le. The bass TBH is pretty crap, strange left side may tend to be louder than right side. Other than that, the connectivity is so far best among the true wireless low price earbuds I tried so far.
Sent from Xiaomi POCOPHONE F1 using GAGT
midlusionz
I own both. Imo T5 is better. E12 need some tricks to have a perfect fit. Youtbe for it.. It helps me
ParkJinYoung
Awei is crap man
Sent from Google PIXEL 2 XL using GAGT
