hpv500
juz nw went down to Sitex to try out some wireless earbuds, 1More and RHA trueconnect, both the bass overbearing sia....even with my poweramp app EQ set as flat.
ended up decided to get lypertek tevi from carousell, its perfectly balanced all round....
agent_719
lypertek tevi is on lazada for ~ $88 with hsbc voucher (use a ~$1 filler item)
just hooted one.. first pair of TWE.. hope it will be good
gong318
went ahead and ordered mpow t5 and lypertek tevi on impulse. Will test it out against my sabbat e12 ultra and see which one I prefer the most and return the ones I won't be using
Sent from OnePlus GM1910 using GAGT
gong318
Why u sold tevi? how does tevi compare to e12 ultra for u?
I've tried both, tevi has better clarity and wider soundstage with a tighter bass. sabbat e12 ultra has more bass but it's warmer and the soundstage is narrower.
camile89
Sadly my e12 ultra sound keeps cutting off. Very annoyed. I did try resetting it but still same. Read online about others having the same issue.
So now thinking which earbuds to get next..... but tbh dont know which to try out.
gong318
my e12 ultra no issues with cutting off, but the seal on the tevi's is definitely better
limz777
sound cut off on aptx mode ?
boxedfish
I just tried my QCY T5, and I must say it's game mode does make a difference in the latency.
it's slightly slower than my wired headphone, and much faster than my other Bluetooth ear buds.
how to activate the game mode? by app? bought this for my wife, so haven't got to play around with it much.. but on first listen, pretty amazed by what $35 can get you in terms sounds quality of TWS.
DigDub
Airpods pro the connection is super strong, the best I've used of any TWS earbuds so far. It also combines the left and right channels into one earbud if only one earbud is used.
