Nakedtoes
huh... cannot visualize... how to punch a hole sia.
Foam tip squeeze inside silicon tip? But like this won't have foam tight isolation right?
Sent from Xiaomi POCOPHONE F1 using GAGT
this is how it looks like... u can go diaso buy the hole puncher.. is for belt.
Project_Xco
if i have a budget of $100 for TWS for 1hr jogging, which one would be recommended?
current redmi airdot audio keeps dropping.
rainbow99
currently using mpow and lypertek tevi but don't seem to pick up the voice well during whatsapp and voice calls. A lot of background noises picked up as well. Which earbuds can work better? would appreciate advice. thanks.
Gadgetfreakloh
It is no surprise that they do not work well. They are so far from your mouth and definitely will also pick up alot of external noise along the way. Unless they are using good mic noise cancellation then will be a problem. Perhaps the good one for voice might be Jabra and Plantronics.
Nakedtoes
read so much about TWS... finally order the Tronsmart Spunky beat... $30 cheap sia
Alexz_Hong
Don't see any at that price on local shopping platforms, so I guess it's AliExpress? It's 23-24 USD. Then if you are a new user another few dollars off?
That said, I think I remember seeing it going for like 34.90 on Lazada like a week or 2 before CNY. Not sure if I remember correctly, but if you prefer buying from there maybe just wait for promo again?
Where to get $30?
Pls share! Thanks in advance!
Is anyone facing the issue of both sides of Lypertek Tevi not syncing together to an iPhone ? Currently, I have to manually pair both sides before audio can be heard in both L&R.
Previously, I paired either L or R and audio can be heard in both L&R.
InvisibleXuan
Is Nakamichi TW211 worth it to buy at $120 with free portable speaker? how is the quality of the sound?
DigDub
Ya according to someone on headfi who hooted the nakamichi, the sound is same as mpow t5.
