Computeron
Rec my sabbat liao. But sianz left side softer sia... Contacting seller.
After playing it with equaliser... I think echo buds is better.
But maybe echo buds burnt liao sabbat still new
Now echo buds on sale at 90..
Alexz_Hong
haha. all hooting more expensive TWS. i more interested in cheapo ones. Hooted QCY T5 after seeing good review and the recent promo price on lazada. Was thinking of hooting the spunky beat since now S$34.90 on lazada, but then decided to hoot haylou GT1 Plus instead because not much people have tried that yet, and someone on headfi mentioned he thinks might be even better than QCY T5 in terms of sound. :s13:
Nakedtoes
same same thinking... i researching about xiaomi mi dots.. then come accross QCY then Haylou.. then settle with tronsmart spunky beat... usb c with power indicator with APTX at $30 is superb value for money.. and using same graphene driver for earphone as 1more.. which is abt $100... i would save the money and wait for APTx HD TWS or LDAC TWS earphone instead.;)
Alexz_Hong
Value wise, I think S$34.90 for spunky beat probably hard to beat? QCC3020 chip, APTx support, USB-C charging. haha. Haylou GT1 Plus is also QCC3020 chip, maybe just a few dollars cheaper on lazada, and have to buy export set. But still decided to give that a shot since I tried the Haylou GT1 before and thought it was pretty good value too, and I really liked how tiny the charging case was. haha. I'm not a fan of the case of the spunky beat.
For me I mostly use them for jogging only, and occasionally during commute, so don't want to spend too much. :s13: Now just the waiting game. because CNY, both the QCY T5 and Haylou GT1 Plus I ordered on Lazada will probably take some time to reach. :s22:
iteo74
Is anyone facing the issue of both sides of Lypertek Tevi not syncing together to an iPhone ? Currently, I have to manually pair both sides before audio can be heard in both L&R.
Previously, I paired either L or R and audio can be heard in both L&R.
Reset them and re-pair again. You may need try couple times though.. unpair from phone first. Place them into case and then press and hold till both sides light blink. Then take both out and pair just 1 side. Any side. The other will then pair to that.
Had something similar. Tried 2-3x reset and re-pair didn't work. Jaben did it once and it worked.....
DigDub
I'd have to say the sound quality of the Nuarl N6 Pro is godly.
DigDub
Agree, its underrated. Plus 11 hrs of listening time.
Posted from PCWX using iPhone 11 Pro Max
Natural timbre, and no peaks in the mid treble frequency which many manufacturers favours nowadays.
