ylime87
I am considering to buy either creative outlier or soundpeats trueshift 2 .. which one is of a better choice? Or other recommendations ? ◡̈
kogregory
Received my spinfit cp350 and tried it on my fiil t1x earbuds. Got a nice fit.
Replacing the tips of tws is more challenging than replacing the tips for IEM cos' we also need to check if the earbuds can sit well in the case with the new tips on.
The CP350 and CP360 are just like what spinfit claims. Designed for tws and I can sit the earbuds properly in the case with them on.
CP350 are for tws with bigger connecting tips like fiil t1x, where CP360 are for earbuds with thinner connector like sabbat E12 ultra.
As for the size, for me, the biggest fiil t1x tips is impossible to use... too big for me. The default one that came installed when I received t1x is just nice.
The cp350 M size I received is slightly smaller than the default installed eartip of t1x, but it still fits nicely for me. On estimation, maybe u want to try the L size of spinfit cp350?
I bought my cp350 from a local lazada seller. Around $15 for 2 pairs of M size eartips, inclusive of delivery.
Confirm spinfit CP350 can fit Fiil T1X? The description says ONLY with Bragi The Dash Pro, NuForce BE Free8, NuForce BE Free5, Nuarl NT01, Purdio Nexter TX11
Remless
They are not going to list EVERY tws that fits with their eartips, especially fairly obscure brand like fiil.
A bro here also fitted spintfit cp350 on mifo 07 and got good results.
https://www.head-fi.org/threads/goi...too-soon-or-are-we-there-yet.861024/page-1404
'Fitted some spinfit cp350 tips onto the mifo o7 and the sound has opened up further, more spacious sounding and a tad more mid bass. The case can also close with the spinfit cp350 tips fitted.'
As I mentioned, changing tws eartips is tricky as you need to consider the fit into the case as well. Do check the measurements of inner diameter, height and external area, not just for spinfit eartips.
There are also certain tws that can fit more eartips, even those that are not meant for tws. Like my newly purchased KZ S1 (from a lazada sales at $25 for green hybrid version, just to play with it). Its case is taller and compartments are deeper. I can fit 3rd party cheap eartips easily on it and can still close the case.
ParkJinYoung
Got my L size cp350 as recommended by Remless
Wah it fits really well now.
Thanks !!
Sent from Google PIXEL 2 XL using GAGT
Remless
Thanks !!
Nice.
I only aga aga and estimate only since u find the M size of the default fiil t1x too small for u.
For me, M size of cp 350 fit better. The L size should be too big for me.
Plutonian
Anyone looking at edifier tws NB? Anc tws earbud.
https://youtu.be/SZ6ugjHmko4
Features & details
Advanced ANC Technology: Industry-leading Feed-Forward Active Noise Cancellation technology from AMS that offers you true freedom from background noise with enhanced audio quality.
Superior Sound Quality: Φ13mm large graphene diaphragm delivers a much deeper and punchy bass with the rich details of sound reserved, which makes TWS NB be distinguished from others.
Up to 33-Hour of Playback: Enjoy up to 5-hour ANC playback and 15 hours with the charging case, thanks to Qualcomm's ultra-low-power architecture. With ANC off, you can enjoy 33-hour playtime.
Bluetooth 5.0 with Qualcomm CVC and aptX Technology: Enjoy fast transmission and clear calls within 10m(33ft), thanks to Bluetooth 5.0 with Qualcomm aptX audio and Laser Direct Structuring antenna.
Ambient Sound Mode: ANC technology gets you fully immersed in the music, while ambient sound mode keeps you informed from the outside world. (Note: Control it by the button or “Edifier Connect” app)
kazuki666
Anyone know where can get bomaker? Saw the latest model review like very good
Sent from Xiaomi POCOPHONE F1 using GAGT
Hir0shi
Hi all, previously before this whole ** started I tried on the Jabra Elite 75T and really like it because of its strong bass but didn't purchase because my current earphone is still working.
Now that my earphone is going to uplorry soon I would like to ask fellow experts here, any alternatives to the 75T with equal or better bass? I know that best to listen myself to judge but unfortunately current ** situation doesn't allow me to.
Top priority is bass, budget around <$250 for a TWS.
Appreciate all help! If not I shall just go for 75T.
Computeron
i pk with 75t... same ear tips.
sony wins.. no wonder is class top teir.
but its anc like not very mind blowing. thou. just lesser noise
Gadgetfreakloh
Wf anc is good but i felt that the passive nc is very poor. No matter what type of earbuds tips I use, I am unable to reduce the noise level. It seem that it is quite open air. :s22:
