bedlamite
If my usual size is M. You mean I should get a size down to S?
Everybody has differently sized ears, so I hesitate to make a general recommendation, but that’s the popular opinion regarding these tips
https://www.head-fi.org/threads/a-review-of-mandarines-foam-tips.825397/
Sizing down worked for me as well.
Stuffing foam into eartips isn’t anything new, Sony’s hybrid tips were the pioneer but these Mandarines are much more well-built. The silicone’s high quality and the foam is more resistant to wear and tear (not an issue if you don’t remove the tips from your IEMs, but if you have a ton of IEMs and don’t feel like getting expensive eartips for all of them, popping out the Sonys would eventually dislodge the foam from inside the eartip).
JVC spirals are great but they’re perennially out of stock, I’ve had good fits with Spinfits, cheapo NiceHCK EJT-14s and these Mandarines. Lucky thing now got local retailer, the first ones I got had to be shipped from Europe through EBay.
Remless
I find that the T1X biggest ear tips are too big , Abit not comfortable. But the medium size is too small.
How to get something in between:s13:
Sent from Google PIXEL 2 XL using GAGT
Received my spinfit cp350 and tried it on my fiil t1x earbuds. Got a nice fit.
Replacing the tips of tws is more challenging than replacing the tips for IEM cos' we also need to check if the earbuds can sit well in the case with the new tips on.
The CP350 and CP360 are just like what spinfit claims. Designed for tws and I can sit the earbuds properly in the case with them on.
CP350 are for tws with bigger connecting tips like fiil t1x, where CP360 are for earbuds with thinner connector like sabbat E12 ultra.
As for the size, for me, the biggest fiil t1x tips is impossible to use... too big for me. The default one that came installed when I received t1x is just nice.
The cp350 M size I received is slightly smaller than the default installed eartip of t1x, but it still fits nicely for me. On estimation, maybe u want to try the L size of spinfit cp350?
I bought my cp350 from a local lazada seller. Around $15 for 2 pairs of M size eartips, inclusive of delivery.
ParkJinYoung
Sound great. Will order :s12:
Thanks!
Computeron
just ordered Sony-wf1000xm3, paid only s$50 with credits in amazon.
see which one is better compare to my current elite 75t
Computeron
i got usd140 in wallet for more than a yr. then saw one listing in amazon brand new sealed set only usd160.
so i used my credits to off set.
twocupsoflatte
Hello, does anyone have any experience with Plantronics Blackbeat Pro 5100?
I’m actually looking for a TWS under $200, for commuting and music/Netflix.
DigDub
Didn't really like the sound. You can consider Samsung the original galaxy buds. It's about $140 now since it's old model already. Still supported by Samsung and the app is useful. The sound quality is also very good.
Computeron
actually buds+ is already below $200. $155?
then highly recemmend buds+
Crayon Shinchan
Those using t1x. Any earbud memory foam to recommend?
My existing one for wired earphone seems to be too big. Put already can't fit into the charging case
Sent from
东汉末年至三国时期(刘备→刘禅) using GAGT
davidwong
Ya I am also looking for one that will fit the charging case
Sent from
东汉末年至三国时期(刘备?刘禅) using GAGT
