storm913
just use whenever i wanna use lo.
The only issue I have is not the ear buds but the case. It is not as good as Creative one. The flip is very easy to spoilt.
You mean you think it's very easy to spoil, or yours spoilt already?
musicsg_com
Reviewed the Earfun Air. It's brighter than Earfun Free, less bassy, better design quality.
Other comparisons:
Pamu Slide – strong fat bass with subtly clear treble, slightly better than Earfun Free, but Earfun Air is certainly offers brighter treble.
Redmi Airdots S – with almost similar tuning as the Earfun Air, but the treble is slightly more brittle and sharper. Overall, simpler build without all the fancy specs.
Ugreen HiTune – offering more balanced tuning with less forward treble compared to Earfun Air, overall tighter sound staging.
Creative Outlier Gold – the mid-treble (vocals) on the Outlier Gold is more prominent, the upper-treble (percussions) is less sizzling.
More TWS earphones review
tinyspeck5
Can I just say I really enjoyed using Redmi Airdots? Affordable especially cause I got it from Shopee and really good quality for the price, will recommend
Other comparisons:
animeonegai
the truengine 3 SE... I used the large silicon and it is able to seal any gaps in my ear. Tried the comply and medium size, I will feel some movements.... I wonder why.
Outlier air has only 1 size and is able to seal my ear. haha. :s22:
Dolcefarniente
not sure if you had used the correct method of comply.
must compress first before insert into ear. and let it grow back up inside your ear to seal it
doki81
finally my beans is here..Korean set..
Sent from Samsung Note 10 + using GAGT
update 1: sound impression is good..more to the warm side even though it's a open ear concept.
fitting : no issue, just insert and it will sit nicely
ANC: can't really test out much on this as my house now is quiet. the ambient mode is now gone. kinda miss ambient mode as it's good for commuting.
Gadgetfreakloh
No need ambient mode as is very open with not much seal. Saw review that the ANC is not effective as it can only cut out the low frequency noise. For ANC to work well. Passive noise isolation is necessary.
Kindly do a review of the ANC. Appreciate your feedback.
guile
Soundpeats True Engine 2 for $85 Flash sale. Worth getting?
Sent from Samsung SM-N975F using GAGT
teosamuel4
Anyone with the wf1000xm3 experiencing constant dropouts/stutters? Dam jialat sia. I've had it for close to a year but recently got alot worse. Stuttering multiple times every song.
chesterqw
it's probably due to tracetogether; uses bluetooth, and the more people have it on, the more interference.
doki81
will find time to test out when i can..cos i don't know...for me the seal quite good.
the bass doesnt sound like it's open concept :s13: i did try not to wear too deep as it's not the correct way. still bass quite good.
justln
Did you update the firmware with the Sony Headphones app? Got try another music player?
Toader
Close applications and clean your phone to free up memory space ,both internal as well as ram. (So called defragment ~) then reboot your phone. Also do not cover your mobile "antenna transmitters and receivers".
animeonegai
Did. but it doesnt feel large enough to seal the ear as compare to large size silicon earbud. :s22:
storm913
Mine, i will feel too tight after it expands. But true, SE 3 fitting on my ears does not feel super comfortable for long use.
tohchr
Can share the link which web u got it from?
Open concept mostly doesn't have ambient mode cos it's not seal inside ears.
Posted from PCWX using EVR-AL00
doki81
got it from this qoo10 seller...shipping took like 4-5 days after they ship from korea.. now the price is even cheaper... $180 compare to when i get it for $188 :eek:
price for being early adopter :( but i have to say...the ANC according to review is not much effect due to open concept ..i dont have chance to test out yet as wfh.
Galaxy Buds Live aka The Bean link
