ksksksks
Think they have their own ldac technology but thought that’s a battery sucker :o
Headphones? Some improvements but they removed APTx and it's a no no for me cos I played some games with it and the latency is there without APTx support. I still keep my xm3.
Posted from PCWX using EVR-AL00
reno77
Just bought the Samsung buds live from q10. $180 after the $20 discount.. Hopefully i like them because I'm getting tired of the rubber tip of my other earphones getting stuck in my ears when i remove them..
Nakedtoes
Teach u a good method.. U know those plumbing tape? Those white one.. Tape small strip on the earbud nozzle. Then insert in yr silicon tips.
Crayon Shinchan
Previously bought FIIL T1X.
Just curious. Is wf-1000xm3 still one of the better earbuds out there? Or got better price point that match it recently?
Sent from
东汉末年至三国时期(刘备→刘禅) using GAGT
DigDub
Sent from
Can try Panasonic rz-s500w.
gong318
Sent from
quite curious too, been using budget tws, dk if should invest in more expensive option
ksksksks
Maybe try the fit first cause quite a heavy earbuds.
Still prefer AirPods Pro over wf 1000xm3 for Anc
Sent from
东汉末年至三国时期(刘备?刘禅) using GAGT
onlinehero
justln
their review seems good enough for my normal usage of runs, exercise and commute.
but hais missed the national day sale now price went back up by $50 :(
Sent from OnePlus GM1910 using GAGT
I don't recommend any Anker products unless you can deal with the white noise lottery. Some reviewers don't even notice it but many others do for some Anker earbuds, not sure about this model.
Their customer service is top notch if you buy directly from them or Amazon, not sure about local.
onlinehero
this white noise lottery issue is audible to the common man or only audiophiles can detect it?
animeonegai
soundpeats truengine 3 SE just touch down on my desk. Tried it. It is definitely better than outlier air. A worthy upgrade at a much lower price.
I have yet warm up the 2 dynamic drives btw.
justln
It's not an "audiophile" issue, anyone can hear it and once you notice it, it's damn irritating. Many other cheaper earbuds don't have it so Anker being more expensive experiencing hissing is ridiculous.
As I've said, you can always try the Anker white noise lottery.
Dolcefarniente
how are you going to burn in the TWS? with 4-6hrs power only? i just received mine also
animeonegai
just use whenever i wanna use lo.
The only issue I have is not the ear buds but the case. It is not as good as Creative one. The flip is very easy to spoilt.
ksksksks
Yeah it is a common issue with their earbuds.
If u always blast ur music maybe ok, but certainly there will be time u put it to Low volume or complete silent while wearing it will be quite audible from there.
