Computeron
just rec my S size XELASTEC tips... got the right size this time.. really highly recemmanded tips.
DigDub
Hiby wh3 seems interesting, armature and dynamic driver. Can change the bias to either the armature driver or dynamic driver to change the sound signature.
vofzxy
https://www.indiegogo.com/projects/pamu-quiet-music-in-noise-out-never-fall-out/x/3576533#/
anyone buy in?
Toader
Wah the specs like sibeh good
Sent from Google PIXEL 2 XL using GAGT
Hope the battery life is good and able to last long, as well as build quality and design. Sometimes you just get the bad vibe by just looking at the device.
davidwong
3.5hr with anc and con for me no app to tune EQ but seems like the anc very good but the ambient mode sux, if no app how to do firmware upgrade?
Toader
I wear it without noise cancellation. Its more than suffice for me.
You need to download the earphones application in order to update your earbuds.
If thinking of battery life still not as good, get the WF-SP800N . Its sound quality can adjust to nearly identical to WF-1000XM3 quality, with 9 hours battery life (noise cancellation) and 13 hours without noise cancellation. Water resistance. I personally washed them with soap! Only short of NFC if thats your checklist.
vofzxy
how to adjust ah?
manually go and tune ah?
https://www.jabra.com/blog/whats-nfc-and-why-should-you-care/
im not sure NFC really really matters
bladez87
Edifier TWS2 True Wireless Earbuds (BLACK) $90
1MORE ColorBuds True Wireless In-Ear Earbuds $120
Huawei Freebuds 3 True Wireless Earbuds $166
are any of the above a good deal?
or is the fiil t1x better?
ksksksks
Think now no more t1x. All buying t1xs
Freebuds3 the fit is good and comfortable - very similar to AirPods 1/2. Good vocals, no deep bass. ANC not as good as AirPods Pro.
1more like no one hoot Liao, last bought their ANC earbuds. Fit is uncomfortable. Still sitting in drawer lol
Recommend t1xs for the price.
Henabi
If want crazy battery life... Can consider mpow M30
Sent from Henabi virus using GAGT
Henabi
A few of my friends bought 1MORE, probably due to Jay chou and say not comfortable and the audio not very good
will the special price t1xs @ $59.99 appear frequently?
Nakedtoes
One of the most value for money tws is edifier x3. Small and comfortable and yet reasonable good SQ.. Battery life is good also.. Bad thing is micro USB and no volume control.
Next is tronsmart spunky beat.. All also give u but touch control abit sensitive..
