DigDub
Anyone here has Cambridge Audio Melomania? New version is coming out in January and now it’s selling at discounted price in US. After adding forwarder charge less than $130 SGD. WhatHiFi gushes about it so seems like a very good true wireless. I am looking for a replacement for my Jabra Elite Active 65t.
Very warm sound with mellow highs.
samsungXP
Sent from Galaxy Note 10+ using GAGT
guile
https://shopee.sg/product/169878610/6362634538?smtt=0.275482764-1608001347.9
Soundpeats Sonic is now sold at Shopee.
It has the latest Qcc3040 chipset which has Aptx adaptive and true wireless mirroring. Reviews not bad actually. Only complain people have with it is the fit. It has 15 hours battery life on a single charge.
Sent from Samsung SM-N975F using GAGT
guile
20% coupon is out. Grab now. They release it quite late today. .
osmond19
Just received my SoundPEATS Truengine 3 SE from Amazon SG at $46+. The earbuds is really a steal @ $46+ with such good quality of sound and comfort.
It also comes with a pair of complyfoam (how i wish it comes with L size instead of M size) which costs ard $22+++.
How I wish it comes with Active Noise Cancellation to block out external noises...
samsungXP
i think sudio tolv sound better using graphene driver
storm913
You can search on Shopee for compatible foam tips that goes for as low as $1 and test them out :) YMMV
Edit: BTW, I bought 3rd party foam tips, but after using for few months, went back to their original tips.
Darkshadows
I noticed Fiil T1 Pro has an oval-shaped connector. Can anyone recommend a good pair of oval ear tips? Foam or silicone also can. Thanks!
osmond19
Sudio Tolv price is much higher compared to Soundpeats 3 SE worth... Anyway wondering how come Tolv spec said Tolv only support SBC codec?
sajokj
How you managed to get SoundPEATS Truengine 3 SE for $46? Used any discount coupon?
guile
https://shopee.sg/product/155135628/9102812270?smtt=0.275482764-1608105666.9
New Soundpeats Sonic on Flash sale if you would like to try the new Qcc3040 chipset with Aptx Adaptive.
dreamaurora
My Jabra Elite 65t Active left earbud can only produce very soft sound now despite the buttons still working. Sigh, no more warranty already.
Just ordered a Mavin Air-X. It seems to be the only one that fits my requirement of having good sound quality, suitable for running, and below $100 now. Seems like from this thread you all have good feedback for it, but for some reason its discontinued now?
guile
Try resetting the earbuds and re-pairing?
Had an issue with my dad's GT1XR where the left side was very soft cos he accidentally dropped it. Resetting it somehow makes it work properly again.
dreamaurora
It's an issue with the proximity sensor. I used to solve the issue by using a small needle to poke the tiny hole. Now the trick does not work anymore. The left ear bud will only go full volume when I literally jam it further it inside my ear. It's a known issue with the 65t.
Asure7
Thanks for the review.
Was actually looking for budget ones (saw $20-25 ones on lazada), but worried about connection issues etc.
Ended up buying these at $51+ though... Overall quite happy with it. Feels comfortable.
Gonna be using it when i go to sleep (ruined a few wired earphones and/or ended up with sore shoulder when body rolled over the earphones while asleep).
