Nakedtoes
i tried the XELASTEC tips... not bad but still i need to insert foam into it to get the isolation i need. The tips after a while will expand just like what a tpu case like. Maybe due to the foam exerting pressure causing it to enlarge. Once u put in want to take out quite abit hard... very sticky and they are very dirty also cause all yr dead ear skin and etc all will stick onto the tips.... and actually not as soft as silicon tips... i still revert back to JVC spiral tips. Cause the hole diameter is bigger the sound signature is different too... JVC tips with foam mod is the best ever tips for me..;)
Darkshadows
Sounds like ambient mode.
https://www.head-fi.org/showcase/fiil-t1-pro-bt5-2-ipx5-anc-tws.24694/reviews
The guy has no idea what is ambient mode but try what I quoted to turn it off. Basically it lets you hear outside noise so that you will not be lost in in your TWS since it shuts you out from outside noise pretty well. Heard it's useful for like cyclist.
Thanks but I do know about ambient mode. I've switched all 3 modes and I will still hear louder outside noise coming into my Right earbud in all 3 modes. It's only the Right earbud that has this problem. The Left earbud is working perfectly.
Does anyone know if Fiil has a service outlet here? I probably need to let them check n service it if it's faulty.
ksksksks
No they don’t. Which store did u buy from?
Computeron
chesterqw
correct tip size for XELASTEC? i like them cuz they sticky; so won't slip out of my ear canal :s13:
cryn79
Hi all,
Thanks for recommending to give sound peats a try, bought it on Lazada Black Fri sale for $31 ( before coupons:$61).
SoundPEATS for True Air Bluetooth Earbuds
As per below are my reviews:
song on youtube: Crowded House - Don't Dream It's Over
Phone: Samsung Note 10
Song
-Although it lack bass, the sound quality is still very clear.
- No latency
-Easy setup
Phone calls
- My friend feedback there was an echo when he heard my voice
-I could still hear my friend's voice but quite soft.
- When my radio was on, my friend could not hear the radio, I believe the noise cancellation function works
- When pairing for phone calls, pls rem to choose "Soundpeat True air" instead of "soundpeats True air L". I initially had problems getting to work for making calls.
Overall, it was comfort for ears and I would recommend it for a budget earpiece.
https://www.lazada.sg/soundpeats-fo...llation-atpx-code-i669132076-s2037778220.html ( no referral link)
Thnks again for recommending!
Hi all, I have problems showing the image, can someone pls help me? thnks!
lullullullul
Guys FIIL T1Xs or FIIL T1 Pro? Using on iPhone and will be my daily driver for music, occasionally for playing mobile games and also calls when it comes in when i’m using the earphone. Pretty stuck between these 2 options.
ksksksks
T1 pro =:p
Wait double 12 Shopee
Vulpix
Moderator
Moderator
Does anyone know if there is any spinfit that will fit the Fiil T1 Pro? I really like the Spinfits, super comfortable and they actually have a size that fits me great. The Fiil T1 Pro the included just isn't the right fit. The slightly bigger one is too big, the smaller one is too small. :s13: First world problems.
