musicsg_com
I am kinda torn between Jabra Elite 65T and the active version.
Will the active version comes in more colours? The dark blue/copper match kinda weird.
Would the non-active version be suitable for cycling? As in sweatproof.
Sent from a tiny corner in SG using GAGT
Jabra Elite 65t is IP55 rated, which means it is sweatproof. Comes with a 2-year warranty against damage from water and dust. Hence, no issues with cycling.
tskeng
Hmm... looks familiar?
kazuki666
If price aside, which true wireless would you rate best in terms of connectivity, sound, and comfort?
I seem to see mostly here using Jabra elite 65t
Sent from Xiaomi REDMI NOTE 4 using GAGT
Albedo
Why not take Jabra elite sport which has hrm?
Sent from LG-v30 Plus From Your Heart using GAGT
Didn't really look at Elite sport since I don't need the HRM and that's is a waste on battery life.
IP55 and IP56 got significant difference?
Zijin_
gotten a pamu too. work great and the signal very very seldom drop. and i think its way better than crazybaby in term of audio delay.
the creator explain that the tronsmart is a OEM of their product. so good idea to get this instead of pamu now that is it so expensive
xenocide
now PaMu is $79 and 20 days back order.
TronSmart is ready stock?
Tronsmart is better value and if PaMu can sell for $29 initially... think cost is way lower
Gadgetfreakloh
After using so many true wireless. There is no perfect one to be frank. If I were to choose. It will be the bragi dash pro. 5 hours battery life. 4 gb build in storage for offline music. The only water proof one that can go swimming. Knowles Balanced Armature. Build in sport assistance with heart beat monitoring. No audio sync delay. Full volume and function control using swipe. Also have motion control, sound pass thru etc. Very comfortable fit and i can wear them for hours without pain which i have problem with E8 and Icon X.
Sound quality and bt range very similar to E8. This is now the most advanced true wireless in the world.
Roflcopterr
Hi guys
Where to get the best deal for Jabra elite 65T? (active and non active)
CrossFaith
Hi all, I am torn between Jabra Elite 65T and Jaybird Run. Any bros can advise the pros and cons between these 2 (in terms of sound quality, comfort level, IP, etc.) Thanks in advance. 🙏
tambaididi
Go audition both of the TWE as different people has different fit. I prefer 65T over Run. Sound quality, i found 65T more balanced.
musicsg_com
Jaybird Run audio quality loses to Jabra Elite 65t. It uses Bluetooth to connect to both earbuds, while Elite uses near field magnetic induction. The build is also not as solid.
I love Jaybird Freedom and X3 sounds, but the Run is far from that quality.
CrossFaith
Thanks guys for the input. I just got my hands on the Jabra Elite 65t.
Just curious, how long do I need to charge for the first cycle? Also, how do I know if it’s fully charge? Pardon me, this is my 1st TWE.
meekiatah
I gave up on ear buds and invested in Bose QC 35 II. Was using Samsung IconX 2018. It seams too have this issue of left bud not working totally and need to use the reset pin to reset it. It happened 4 times during the 3 months that I had it and during this period, I used the ear buds sparingly, only while I'm on trip where I'm stuck in plane or ferry. Brought it to PS Samsung CS and they can return to me saying it's got nothing wrong!! Even this issue is reported in IconX support forum. Anyway, rather than keep spending money to get the perfect ear buds, I invested in the QC 35 II which is something I had been eyeing for quite some time. No regrets.
hellhole
i also got this pamu... not bad so far.. but.. the charging box is... :|
i still like the zolo+ from anker..
best way to test a wireless ear bud... get it connect.. go walk around sim lim.. hehe.. see how mnay time it get distortion
DXMachina
Although the staff at Stereo recommended 8 hours, I doubt you need to do that with modern battery tech.
For both the case and the earbuds, a full charge is a constant green LED.
Albedo
I know the Jabra Elite Active 65t is not available yet, but what does it have over it's sibling, the Elite sports that would be worth waiting for?
The sports got 3 years warranty and that's very tempting.
doki81
3 years warranty against sweat :p
Albedo
Yes, especially when SG weather so hot and I sweat a lot.
