bendoggo
Okay my airpods 1st gen finally died after 4 years and i need a new one, has anyone tried the blackdot pro wireless earbuds? i looking to budget for now
Simiishthis
Any earphones with good mic recommended? Preferably within 100 bucks. I got an outlier gold but it keeps disconnecting intermittently and the mic pickup is horrible...
woodsteel23
Hi all! I’m using an iPhone and bought a Fiil T1 lite online.
The instruction manual is in Chinese, can’t really understand it.
Upon first time unboxing, I just took out the earbuds out of their case, went to the Bluetooth screen in my phone, turned on Bluetooth, found “Fiil T1 lite”, clicked on it to connect.
I then realize that the instruction manual said something about automatic pairing, but I did not do it straight out of the box.
Does that mean there is a way to just turn on Bluetooth on my phone from the lockscreen, and the earbuds will automatically connect,?
Thus saving a step of having to unlock my phone, going to settings, turning on Bluetooth from there, choosing the earbuds, then choosing to pair them to my phone.
Asure7
Not sure what you mean... you want to toggle bluetooth from lockscreen?
just swipe up/down to access Notification Centre and u should see the bluetooth icon
tohchr
Automatic pairing is available in most earbuds. Make sure your phone bluetooth is turned on. Then take our your earbuds, it will automatic connect(pair) to your phone. This should be what the instructions manual trying to put across.
For the first time, manual pairing is required which u already did.
justln
Buy wired earphones with a mic piece, tried different wireless earphones all mic sucks.
tohchr
USB C to 3.5mm lo, no choice.
That's the only way. Luckily I still had old USB-C to 3.5mm from Huawei phones. That cable is a gem to me because nowadays companies even refused to include charging brick liao. :eek: Next time I think charging cable also dun give
kimsix
huawei freebuds 3 from Amazon sg, can drop as low to $60+. mic is good
and convenience of auto pairing like airpod that outlier gold can't do
Cheese Steak
I bookmark a few listings and check at some point of the day :s13:
I’m done with my fiil shopping.. hope no more new models
I was wondering why my shipment was so long, then I realised I didn’t make payment for my t1 lite. Wasted.
xmen
Can Anyone recommend ears foam for soundpeats truengine s3? Can any foams do or must be specific brand?
