chesterqw
ZhugeLiang 諸葛亮;133047946 said:
Want to find a budget TWS earbud
Is blackdot Pro wireless a good option?
Sent from Imperial Chancellor*(丞相) of*Shu Han using GAGT
i think something like the Haylou GT1 Plus would be less of trying your luck to see if they are nice or not
kelvinti
Gotten my Soundcore Liberty Air 2 Pro to replace my Huawei Freebuds Pro.
I must say that it sounds awesomely amid the higher treble out of the box but again the preset Treble Reducer EQ (out of the 22 preset EQ) does the job well for my listening preference and my ears.
I know it is very subjective but I don't like and that my ears can't take high pitch or high treble.
Awesome awesome music sound quality for all type of music. No regret replacing the Huawei Freebuds Pro. :)
As we know that Huawei Freebuds Pro is already sounds damn good. However, after using the Soundcore Liberty Air 2 Pro (as far as music sound quality is concerned). Huawei Freebuds Pro has to be on the 2nd place for me now.
I'm using it with my Samsung S21 Plus and with its stock Normal EQ setting.
kogregory
Any white noise as some previous reviews have suggested about this Soundcore Liberty Air 2 Pro?
Bardiel
Is the sony 1000xm3 good? Looking around for some ood iem
Currently using sabbat e12 ultra and the random bad disconnection and suggen loud static noise makes me kinda irritated.
Sent from HUAWEI LYA-L29 using GAGT
justln
One of the best on the market, price has significantly dropped too. I'm using it, but it's quite bulky compared to other earbuds and the default silicon tips didn't work well for me, had to find 3rd party ones.
kelvinti
Personally, I don't feel or hear it at all. :)
Likely that the white noise (if there is...) has been fixed with the Soundcore app updates. The latest version is dated March 7th. :)
BTW, as I googled and many state that the white noise is caused by dirt?
kelvinti
Personally, I still preferred the stick design earpiece as so I don't accidentally keep touching the sensors in those rounded 1 piece bud design when putting in and out and when ajhusting the earpiece.
Bardiel
nice, thx for the review.
i saw it as a credit card gift, carouhell all selling at 200. beoing se can lower anot :D
Bardiel
if you samsung phone got the galaxy buds pro also below 200 on carouhell :s12:
Currently using mate 20 pro. Looking to switch to one plus 9 after launch.
Bud pro 360 only work on samsung devices if i not wrong.
Crayon Shinchan
Same price like t1 lite
Better to buy fiil earbuds now
Thanks for the suggestion. Will take a look. Will be using for exercising. So some water resistant is preferred.
I ask blackdot cause like selling well at shoppee haha
Any more suggestion do feel free to suggest.
Sent from Imperial Chancellor (丞相) of Shu Han using GAGT
kogregory
Thanks for the reply.
Computeron
just get it.. used to buy a few budget ones to try.. after got my Sony.. I have stop my conquest liao.
ya the stock eartips also not gd for me ... using 3rd party too.
Computeron
nice ... 1+9....
buds pro I thought all android can use.. got features only for Samsung hp?
Bardiel
nice ... 1+9....
Yea. Saw this on the review wrb
Negatives
360 audio limited to Samsung Galaxy devices
