farmers
Sure, hope this image helps.
Thanks man.
PsyClick
Looking for a BT Earphone to listen to music (mostly spotify), video conference, phone calls.
ANC, transparency etc features are must have.
Looking at the $300 budget range, these are the usual brands one will look? are there any more suggestions? thanks.
Sony
Apple Airpod pro
Bose
Equipment
PC
Ipad pro
Huawei mate 20/Iphone
M1 MBA
Thanks
tohchr
Sony
Apple Airpod pro
Bose
Equipment
PC
Ipad pro
M1 MBA
Thanks
Airpods Pro. Sony's are never good for conference calls, u can ignore it. Bose I had yet experience but out of these 3, Airpods Pro will be the best fit due to ANC, almost perfect transparency mode (sound exactly like u never wear earbuds). Else, u can also consider Huawei Freebuds Pro for the superb voice call and duo devices connected at the same time.
carmelmore
Do Airpods Pro and Freebuds Pro feel the same in the ear? Their shape looks identical.
tohchr
Feel about 80% similar in the ears. Transparency mode ON, Airpods will sound more natural in the ears. ANC wise, no comment for both cos I dun not use this feature at all. Freebuds Pro had an advantage of adjusting the volume on the buds itself and where Airpods Pro had to use the phone or siri to adjust the volume. If all your devices are Apple, then it's a no brainer to go for Airpods Pro due to seamless switch between all the Apple devices. If your devices are mix bag of Apple and Orange, then can consider Freebuds Pro. Most of the time, I went to challenger to test the buds out before making a decision as they had sample for customers to test.
Henabi
Sony
Apple Airpod pro
Bose
Equipment
PC
Ipad pro
M1 MBA
Thanks
since you use a variety of Apple products, its best to go for the Apple Airpod pro as the product is meant to work effortlessly with your MBA, ipad and iphone
007Mi6
Ordered the FIIL CC Pro, think only recently launched. To replace my dying FIIL T1X which is more than a year old
Haven't reached yet.
sajokj
Not sure why suddenly my right earbud of FIIL T1X stopped working, not even connecting to the phone, no lights too. but left side works. Any fix? its under warranty, had already contacted the seller.
007Mi6
Maybe the battery overworked in master mode. My right T1X also battery not able to hold the charge after about 10-11 months
