Henabi
Just curious. Have you guys ever take a sniff at your earbuds and the hole which place them back into the casing? I guess is my sweat, oil and hygiene, there is a lingering smell not that nice.
On this topic. How do you guys maintain your earbuds/casing? Do you use soap to wash the silicon bud after every use?
I use alcohol wipes… have aplenty around my house thanks to covid XD
just take one piece wipe it thoroughly
kazuki666
Thanks for the inputs. I did think of alcohol wipes, but it sounds wasteful and not environment friendly to wipe small earbuds daily with a whole piece.... Thats also why I took out the silicon buds to wash with detergent. But I am concerned if the material will break if wash that often also... :unsure:
As for the casing hole itself, i try to spray some alcohol onto a cloth then wipe hopefully it helps to cleanse...
rECKleSSfElla
Huh? You go and wash your earbuds with detergent and water? Or you mean the eartips? Your england i read until one head murky water. Whats so wasteful and environmental unfriendly about using alcohol wipes? A box of 100pcs only sell for $2 or so. If you dont want to "waste" alcohol wipes then use cotton earbuds dipped into hand sanitizer(should have plenty of government issued ones lying around) and clean your eartips or charging case accordingly. And why are you having to do cleaning daily? Your ears got so oily and dirty until you have to sanitize your earbuds after each use? If that is really the case then you should treat the problem at the root i.e. clean your ears more instead.
k4k488
[link removed by mod]
what the difference between JP small version and normal version?
dinosaur2776
Guys i used to use creative outlier..
Then i change to sennheiser
My budget ard 150 to 250
Is there anything out there u guys feel better
Purely for listening to music.. So sound quality. I like mine bassy.
Tempted to change to samsung buds
Henabi
Can consider sennheiser momentum 3…
Lazada now 11.11 can get to 250
or edifier W240TN
Henabi
W240TN so good can challenge senheiser?
Personally i feel the sound quality of W240TN is good enough for me not to add extra $$$ for more expensive wireless earbuds
But Whether is it able to match up with anc tws earbuds which are 2-3 times more expensive
i feel its pretty personal.
plus, he mentioned his budget is 150-250.
dinosaur2776
or edifier W240TN
Bought the sennheiser. Awesome stuff
I like how they customise the sound quality for you. Cos i never understand how to manually change the equaliser. So they customise for me using the app
Henabi
awesome!!!
enjoy them in good health ^.^
Henabi
finally I just completed a real day in life test of the Apple AirPods Pro Gen 2....
Not easy to be playing music continuously throughout the day, as I go about running my errands.
Started testing around 7:20am @ 100%
Volume level set at 50%, ANC ON, Spatial Audio OFF
EQ neutral, songs playing from Spotify
dropped 1% after 15mins
86% @ 8:23am after I finished my breakfast
65% @ 9:33am
49% @ 10:26am
28% @ 11:45am
10% @ 12:49am
LEFT 0%, RIGHT 4% @ 13:23pm
LEFT 0% @ 13:23pm, RIGHT 0% @ 13:27pm
Henabi
hey fellows!!! I managed to complete another Battery test grind, and this time, it is the AirPods Gen 3
Started out around 9:00am in the morning
Spatial audio OFF
Volume level 50%
L EarPods 100%, R EarPods 100%
Music stream from Spotify
LET'S GO!!!
Battery life closing to 70% 11:34am.
2hrs 34 mins into battery test
Battery life at 44% 13:23PM
4 hrs 23 mins into Battery test
PS: I had to charge my iPhone 12mini mid way as the battery was draining very fast
Battery life at 20% 14:30PM
5hrs 30mins into Battery test
I got home, connected the AirPods 3 to my M1 MacBook Air and continued using it while I am doing my work...
10%!!! at 15:28PM
6hrs 28mins into Battery test
2!!!! 2%!!! 16:16PM
Anytime now....
7 hrs 16mins into Battery test
REACHED ZeR0!!!!!! 16:22PM
7hrs 22mins into Battery test
oh! R EarPods still has 3% left....
So... L EarPods died first
Finally @ 16:30PM R EarPods RIP too...
Total runtime: 7hrs 30mins
grandorder302
Does anyone know if there is any other similar brand with the same earbud design as Jabra elite active 45e?
I'm not sure what to search on google for this type of earbud design.
Henabi
most websites call these "Wireless neckband Headphones or Earbuds", cuz there is a rubber/silicon wire which goes behind your neck.
Actually many brands offer this design
- JBL
- Beats
- Sony
- Sennheiser
- Creative
- Samsung
- Plantronics
- Audio-technica
Some have ear hooks, some come with ear wings....
grandorder302
- JBL
- Beats
- Sony
- Sennheiser
- Creative
- Samsung
- Plantronics
- Audio-technica
Sorry, what i meant was the shape of the earbud design, it's shaped like an airpod but I don't know what this design is called.
