peaceheart
After using a few affordable brands like AWEI, QCY, MPOW, Creative is slightly higher priced than the former. I have "cheapskate" ears, these affordable bluetooth earbuds serve the function for listening music while commuting to work and home. I haven't feel the need for more branded and higher priced earbuds so far.
End of the day, I always tell my peers to try first, don't judge them by the price and brand.
Of course if one is using iphone, I think airpods will be better.
Haha I also use cheapskate brands like alpha & Delta, edifier and mpow for commute and sports. Creative is indeed more expensive but still acceptable. Other major brands are even more ridiculously priced.
micshang
Hi, hope to get some advice here.
Currently I'm considering the following;
Liberty 4
JbL Live Pro 2
Earfun Air Pro 3
All the specs are quite close. I'm have a hard time deciding which to get.
Hope the experts here can shed some light on the 3 buds.
Thank you very much!
Frankly I have not encountered much issues
BT interference usually during covid days with the TT token and TT app. Now is ok
I also dunno why my $50 Fill got issue then I tested with my cheapo free BT ( no problem ).
I thought BT tech should be OK no problem one..
kazuki666
Guys, Creative outliers pro selling at Shopper now for $67, not including shipping $1.5 fees.
One of the reasons I stopped carrying my v3 for daily commute use is the bulky casing. And I am the type scare to scratch it while I can't find a cover for it. My edc is QCY HT05.
Henabi
Creative outlier V3 casing is bulky thats true but thats also due to the large battery inside
its a trade off imo
large battery also means I don’t need to recharge the case that often.
V3 earbuds can last 8hrs with ANR n 10hrs without.
Casing provide another 30hrs
Personally i don’t really care about it cuz the casing is always in my fanny pack
xRenol
Any recommendation between Creative Outlier Pro and Soundcore by Anker Life Dot 3i?
Thank you.
