discoburg
Anyone faced this problem that the music only comes out of the right side E8? I always have to hard rest and then pair again. Anyone know what or where went wrong?
buffon92
I also get this yesterday , then I realised it’s low on battery and I went to charge it . Then Ok Liao
Nitrile
Just got my elite active 65t. The sound quality is better than my AirPods but the connectivity SUCKS. The left earbud hisses all the time and the Interference in the left earbud also drives me mad when I use my computer while listening from my phone.
doki81
you using in normal environment also have interference?
Sent from LG-v30 Plus From Your Heart using GAGT
Nitrile
outside is ok but left earbud hisses
in my bedroom and some places in my home, the left earbud crackles and keep cutting out every 2 seconds :s22:
I think my WiFi mesh interferes with it.
musicsg_com
The firefly model like quite popular. And good review too
Firefly is by Jabees, I just reviewed the Jabees Beebud, overall product design is good, but while the spec is Bluetooth 5, the audio quality is poor because they don't support aptX.
The Beebud stereo imaging is not the same as other earphones, so the sound staging will sound strange. Otherwise, frequency response is good, bright treble, firm bass.
Gadgetfreakloh
Should not be wifi interference as slave is using NFMI. Unless your surrounding is a big magnet. I think you may have a lemon set. Get it exchanged.
boOz08
your earbuds using the latest firmware?
i contacted jabra support multiple times to ask them about the crackling sound.. they cant give me a solution to it than replace my device...
i replaced once before.. with oem firmware if got interference only will disconnect but wont 'crackle'..
once i update the firmware, the crackling is back :(:(:(
FireHobbit
The 65T I tried at takashimaya.. Really sound quite bad.. Do have the crackling sound
Nitrile
Yes. Updated it to the latest version after unboxing it. Sian. Looks like need to go down to orchard. Damn lehcheh.
boOz08
can try change already dont update firmware first..
Connection drop will not have crackling sound.. but update liao confirm have.. haha u can try :s22:
jabra side cant give me any solution to this.. only tell me maybe set fault ask me replace :(
