Bardiel
Earbuds with stem to me is easier to handle and they also stay in the ear better. Anyway i vote for Liberty 4 NC. The price is too good. I’ve seen it as low at $65 during sales period when you can stack the vouchers.
Thanks for the SIC. will camp till around that price and hoot.
hooting to replace sony xf1000xm3 and moondrop space travel.
rerear
For me not much issues with a40, just looking to try others, and have a backup pair cos sometimes I forget to bring them along, to fro.
If there is one thing I am wondering whether can be better on a40, is the ANC, feels insufficient.
But I agree with the comment above that stem type earbuds might be easier to handle, less likely to drop and damage.
edmwing
Nobody here use Redmi bud4 active or lite around $20? I bought the very first redmi bud ($20+) and it lasted almost 5 years until I lost it recently. Need a cheap replacement for teams call or occasional runs.
caterham7
WoShiPro
Just bought OnePlus ear buds 3 at $112. Using OnePlus phone so I find it the best value
Replacing Galaxy buds 1 after 5+ years.
evilduxy
how r the fill now? thinking of replacing my very old fill t1 although still useable? any recommendations for a decent earbuds now?
Da_Hamster
U don't mind me asking how is the sound quality at this price? U used quite some time? Thanks
Yea have been using it for some time, here's my humble opinions;
- Sound quality is decent
- Noise cancellation works well
- Not very comfortable; starts to hurt my ears about 1-2 hours of usage (but you can get used to it over time)
Note; cannot power on/off without the case!
I am a person who prefers to keep my pockets light and simple and simply bring just the 2 earbuds outside (without the bulky case)
Without the case, you can either;
- Disconnect from your phone/device and it will turn off by itself after half hour
- Keep the earbuds connected to your phone to keep it connected and maintain power on (but of course it will drain and go dead within 5-6 hours)
The moment your earbuds turn off, there's no way to turn it on again even if there's still power in the earbuds. You have to put it back into the case and take it out again to turn it on.
With this said, I'm hoping to find another good alternative <$100 to buy, in the meantime I'll use my old Fiil T1 lite
sibeiTrolled
Ouch, as one of the person who "edged" on the 4 NC, i feel bad since it brought down your quality of life.
I was previously eye-ing creative zen lineup.
Seems like the Zen Air Plus is able to fit your requirement of usage without case and <100 SGD?
Here's the manual
https://files.creative.com/manualdn...uvDRoye/QSG-ZenAirPlus-03EF110000000_RevB.pdf
Computeron
my xm4 batt is dying fast now .... dunno wan to get its battery replaced or buy a new TWS
Bardiel
dont have to stack.
just go lazflash. you will see soundcore nc4 at $78.60.
at check out page, it is only $69
thanks. i tried mobile and desktop version managed to get it at 81.60. i guess its a good to go for me. Thank you
ferocity
Past couple of days its actually theoretically possible to get the Soundcore Liberty 4 NC on Lazada for sub $50 by stacking Laz subsidy + Laz coins(up to additional 15% off) + $25 off $50 flash voucher. But have to make use and purchase through their app while the flash voucher is also quite impossible to get.
Lustgan
Anyone tried sony wm5,az80 and sennheiser true wireless 4 this 3 earbuds? Which 1 U recommend
