gregory_choo
True anc earbuds recommendations?
Sound quality 8-9/10
Fit to ear won't drop off. Yes?
Case long battery more than 10h
Playtime more than 5h.
Budget 80 to 100.
Was thinking re-buying anker soundcore liberty 4 nc. Anyone used it? Long playtime? Drop off from ear?
What is the meaning of re-buying ? You bought before ?
caterham7
Ok I'm buying this
Anyone got issue with it?
suggest to consider established audio brands, this black dot is not one of them
many affordable models by established brands, do take a look at them
soundcore
soundpeats
redmi/xiaomi
QCY
edifier
moondrop
creative
veltix
soundcore
soundpeats
redmi/xiaomi
QCY
edifier
moondrop
creative
O man. I buy it.
Locutus
Looking to buy a set of earbuds and as I'm new to this, I'm seeking recommendations from the pros here.
I don't mind spending more if it's really worth it and am looking at either Jabra Elite 10 or Sony wf-1000xm4 due to suggestions by friends.
But I'm also wondering if there are other good and more budget ones worth considering as I don't know if it is really worth spending hundreds on earbuds (my usage won't be that heavy tbh). Hope to get the advice from the bros here.
caterham7
maybe provide some of your usage scenarios, and possible budget
tbh, for casual usage, no need expensive TWS, $30 can get value-for-money models already
gregory_choo
If you don't need ANC, cheap and good, get baseus wm02. About $15-20
ferocity
Edifier lolli pro 3i is one of the first TWS to run on BT 6.0. ~$50 on taobao. Think we will soon be seeing 10+ hours run time on a single charge to be the norm when BT 6.0 becomes more prevalent.
Locutus
Work related purposes mostly, like for meetings, calls and the occasional watching of vids. I don't listen to music that much compared to those around me, so I think the average daily usage will be an hour only or less.
caterham7
tbh, for calls, i recommend wired headset, much better microphone quality
budget TWS, even expensive TWS, the microphone quality not that great, you can listen to mic recordings in youtube reviews
i use apple earpods usb-c at work, RRP $24
williamtyc
any users of soundcore liberty 4 nc can share if this is normal? when putting on the earbuds, the left earbud will take a sec or 2 before it will be of the same volume? and if the left earbud is worn less tightly, the volume might drop and increase. also the touch control for the left ear buds will be disabled if i took the earbuds off the ear and place it back again while playing music. this issues will only disappear if i disable the touch lock in the app, in which it only allows touch controls to be active when the earbuds are worn
TUV2008
I am looking for $100 range or less, use for conference call and listening music, need sweat proof, noise cancellation and ambient sound, what do you recommend?
TUV2008
i am quite confused by this term TWS, true wireless... i thought all bluetooth earbuds are wireless? why true wireless?
