Synchroniza
Hi all any decent and wallet friendly earpiece for running? Previously bought soundcore liberty recommended from you guys and zero regrets. But for running it keeps dropping so hoping for some recommendations in this segment. Cheers
Lustgan
I think for running can try shokz
Synchroniza
Anyone tried the soundcore sport x20? Is the sound comparable to the soundcore liberty 4's? Thanks in advance
caterham7
if normal tws are dropping while u run, can consider models with ear hook?
some value-for-money models
qcy crossky gtr2
soundpeats gofree 2
soundpeats wings 2
1more fit se s30
check online for reviews, to understand the pros and cons, before purchase
ferocity
Redmi Buds 6 Play $11.50 from xiaomi physical or online store. Got mine for $7 during Lazada flash sale. The Buds 6 Play does not have ANC or multipoint but has great battery life while the touch controls can be configured in the accompanying app and are precise and not prone to accidental inputs. The buds are small in size and fit in the ears really comfortably. Sound quality also punches way above its price point. Been using these exclusively for my runs and workouts without any complaints.
Review: https://www.scarbir.com/tws/redmi-buds-6-play-vs-lite-vs-baseus-e19#block-21f0fdf76f6e33ede8e7
Synchroniza
Hey thanks for the suggestion.. do they get loose upon running? I have an in ear liberty 4 but it will loosen up during runs and I have to keep pushing back in. Or does the redmi ones sit much deeper in the ears?
ferocity
I do have to adjust the redmi buds once or twice during my runs but by no means the fit is loose or constantly get that niggly feeling they gonna drop out. I think your issue with the liberty 4 is probably the stem design. Earbuds with a stem are probably the worst kind in terms of fit for workouts.
Alternatively, can consider the Samsung Galaxy Buds FE if you can still find sellers for it. These come with wing tips which are supposed to make the fit more snug and let the buds stay in your ears more securely.
Review: https://www.scarbir.com/tws/samsung-galaxy-buds-fe-review
Synchroniza
Thanks I've just bought the redmi on shoppee 😁
