noobzpro
looking to replace my M&D TWE, what are the best right now max budget 1k
Gadgetfreakloh
interesting will definitely go have a look at it was looking at rex5 also
Noble Encore definately better than Rex 5. Owned them and done countless tips rolling to get the best fit and sound. Wow by Rex 5 when initially got them. Double wow by Encore. Nothing comes close to Encore.
noobzpro
Which tips works best for you
MangoCAT
For those into instrumental (you want pitch to be clear = grand) and new tech of head tracking, can consider Final audio Tonalite
MangoCAT
Tested them. Found it lacked body. Good for details. Not my taste.
I went to test it with the app to change to LDAC. One of the better instruments tws+ for bass and even timbre (piano string notes). Vocals is neutral so ya not the most fun tuning
Anc is worse than my az80 - for those looking for userbility
Beefsteak
Is the Cambridge audio melomania a100 still worth getting now since its on sale price of around sgd 170?
At that price point is there anything better?
tohchr
It's still very good.. at that price point. The battery life is insane. U will forget about charging it for weeks if you are using it like 1-2 hours daily.. The last time I charged mine is actually last year. I used it like 1-2 times every month for an hour or less.
DigDub
Mine got a bug where the ANC turns off every time I take it out from the case. Have to turn it back on manually every time.
DriftKing
Anyone has the Soundpeats H3? Managed to snag one cheap, but looking for EQ suggestions. So far Reddit settings ain't doing for me and I still find base preset better.
