Haha... no need to rush la....
Miss this one still got next promo mah....
Next month got 11.11 sale
Also got Black Friday sale
Use shopback can save $1.80 too.Today's Q0010 promo...nett $52.90
Got my X-Mini Xoundpods delivered today. As others have stated, the bass is there.....and the word I would use for the bass is adequate. This is my first true wireless, thus, not able to comment vs other true wireless but personally, I feel is well worth the price paid.
The only caveat is that I found that if u put one hand over the ear, the sound is cutoff for tat earphone, if both ear piece are covered, sound/music will be cutoff. This means those who wear helmets/hats or in a situation where there is object near both or one ear, u may experience loss of signal.
I believe this is not an issue but a constraint with true wireless. I may be wrong.
Update: went out in the evening with xoundpods and found that when I put my phone in my phone holster on my right, the signal is lost. If holding in right hand, arms swinging, the signal unstable with the signal cutting in and out. However, putting it on the left side have no such problems.
Sorry guys,a dumb qns here. If I'm not using the Xoundpods should i place it in the charging pod or leave it outside?
I dont know about the Xoundpods but pretty sure for most true wireless earbuds the SOP is to put them back in charging case.
Did anyone encounter the same issue??Got my X-Mini Xoundpods delivered today. As others have stated, the bass is there.....and the word I would use for the bass is adequate. This is my first true wireless, thus, not able to comment vs other true wireless but personally, I feel is well worth the price paid.
Definitely not a constraint of true wireless earbuds. My B&O E8 isnt affected by this.
How do you upgrade their firmware???Mine as well. Dont worry you are not alone. Im tired of the xoundpod liao.
The right always break connection. I went to them and they upgrade the firmware and increase the RF signal strength, still the same. If i go again, i think my pretrol will end up more expensive than the xoundpod itself.
When is your delivery? Mine shows 15 Oct. Sianz....
Sent from Xiaomi REDMI NOTE 4 using GAGT
I think xoundpod is not “compatible” with you. Same issue with me, changed a new set, they tested its ok. When I use its the right pod keeps break connections again. I passed to my Girlfriend to use for a day, she has no problem with the xoundpod at all. Passed to my colleague to use for a couple of hours and he has no issue with disconnecting too.
Maybe someone can enlighten me what’s the problem here?
I ordered a pair but I’m trying to figure out if one of the sides acts as a master that re-broadcasts the audio to the other side (slave) or if it actually connects simultaneously.
If it’s a master/slave configuration, it might explain most of the dropouts.
Will update when I receive. And also the details of the “mystery gift.”
